Easy Way to Blow Out the Carbon
    • 9980
    Yes, I digress somewhat.... so you're saying a glass bottle of water, with a copper coil in it attached to the bike battery, fizzing and producing hydrogen which is directed into the inlet manifolds wouldn't look cool, then? Damn! Back to the drawing board....
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      They have developed some low level results with a hydrogen generator for cars but the issue is and seems to remain for many things that bikes have a very limited voltage output to run these things.
      I have used ATF in cars and it does clean carbon rejuvenate oil seals to some degree and loosen any sticking valves. However I do recomend chucking the plugs afterward as it can do a number on them.
      I have never used the water method but I had a cousin that swore by moonshine.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • barrelguy
        • 173
        • Oliver, BC
        I worked with a mechanic many years ago and watched in amazement as he slowly poured a tin of Coke down the twin carbs of his Mercedes. His advice was to do this slowly and not stall the vehicle.
        1980 XS 1100 Special
        Mostly stock & original
        Added Yamaha fairing (w/ 8-track!)
        Torpedo bags
        New paint (still) pending
        Stainless brake lines
        Tkat forkbrace
        Coils from Honda 1000
        Previous bikes:
        1968(?) 350 Harley Davidson
        1977 Yamaha 650
          Any reason this should not be an annual or bi-annual "service" for the engine?
          • jwhughes3
            • 2798
            • Home of the Alamo
            Studies show too much Coke makes you fat. Nobody wants a fat engine
            John
            '81 XS1100H - "Enterprise"
              John
              Huh, I always thought coke made you sniffle a lot and made you thin as a rail...
              • WSL91
                • Feb 2012
                • 427
                • Quad Cities, IL
                John
                Maybe we should run Diet Coke
                1970? Honda Z50... gone
                1974 Honda CB200... gone
                2008 Honda VTX 1800F
                http://www.johnsoldiron.com
                • clcorbin
                  • Jan 2010
                  • 495
                  • Albuquerque, NM
                  The idea of using electrolysis to produce hydrogen that is then burned in an engine that is used to produce the electricity to run the electrolysis is another perpetual motion machine. And like all such machines, they don't and can't work as such. The electrical + mechanical output of the system is ALWAYS less that what went into it and it can never be more.
                  I HAVE seen research were electrolysis was used to produce hydrogen for an engine and the alternator on the engine was used to produce the electricity for the electrolysis... But in that case, the hydrogen was ONLY used as part of a plasma ignition system (thing burning jet of hydrogen gas shooting across your combustion chamber instead of a spark plug...). The engine ran on gas and only a small amount of hydrogen was actually needed for each combustion ignition.
                  -- Clint
                  • Shacknasty
                    • Feb 2011
                    • 379
                    • SFV-SoCal
                    I have an Ironhead Sporty that is my around town bike. Because it rarely sees the freeway (I have it geared for fun, not freeway!) it tends to build up a lil' bit o' crud. I like to clean it out once or twice a year.
                    My freeway bikes only get it every couple of years. They don't build up the carbon as fast. I like to have a look inside the bores and only do it when they need it.
