Easy Way to Blow Out the Carbon
They have developed some low level results with a hydrogen generator for cars but the issue is and seems to remain for many things that bikes have a very limited voltage output to run these things.
I have used ATF in cars and it does clean carbon rejuvenate oil seals to some degree and loosen any sticking valves. However I do recomend chucking the plugs afterward as it can do a number on them.
I have never used the water method but I had a cousin that swore by moonshine.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
http://s1184.photobucket.com/albums/z329/viperron1/Comment
I worked with a mechanic many years ago and watched in amazement as he slowly poured a tin of Coke down the twin carbs of his Mercedes. His advice was to do this slowly and not stall the vehicle.1980 XS 1100 Special
Mostly stock & original
Added Yamaha fairing (w/ 8-track!)
Torpedo bags
New paint (still) pending
Stainless brake lines
Tkat forkbrace
Coils from Honda 1000
Previous bikes:
1968(?) 350 Harley Davidson
1977 Yamaha 650Comment
Any reason this should not be an annual or bi-annual "service" for the engine?Life is what happens while your planning everything else!
78 XS750Comment
Studies show too much Coke makes you fat. Nobody wants a fat engine
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
Theodore RooseveltComment
1970? Honda Z50... gone
1974? Yamaha 100 Enduro... gone
1974 Honda CB200... gone
1981 Yamaha Virago 750... gone
1993 Honda Shadow 1100... gone
2008 Honda VTX 1800F
1982 Yamaha XJ1100J w/850 final, Raptor ACCT
1979 Yamaha XS1100SF "Chewey" Raptor ACCT
http://www.johnsoldiron.comComment
The idea of using electrolysis to produce hydrogen that is then burned in an engine that is used to produce the electricity to run the electrolysis is another perpetual motion machine. And like all such machines, they don't and can't work as such. The electrical + mechanical output of the system is ALWAYS less that what went into it and it can never be more.
I HAVE seen research were electrolysis was used to produce hydrogen for an engine and the alternator on the engine was used to produce the electricity for the electrolysis... But in that case, the hydrogen was ONLY used as part of a plasma ignition system (thing burning jet of hydrogen gas shooting across your combustion chamber instead of a spark plug...). The engine ran on gas and only a small amount of hydrogen was actually needed for each combustion ignition.-- Clint
1979 XS1100F - bought for $500 in 1989Comment
I have an Ironhead Sporty that is my around town bike. Because it rarely sees the freeway (I have it geared for fun, not freeway!) it tends to build up a lil' bit o' crud. I like to clean it out once or twice a year.
My freeway bikes only get it every couple of years. They don't build up the carbon as fast. I like to have a look inside the bores and only do it when they need it.Comment
