Strange engine sound (post debacle)
  • Majortomxx
    • Aug 2012
    • 12
    • Calgary, Alberta, Canada
    Hey again,
    So I got my bike back together, reset the cam timing perfectly, reinstalled the tensioner and guide, everything looked good. The engine rotated without issue, and it seemed like I had compression (sucking and blowing out of each spark hole). Considering these things, I buttoned the bike back up, put some gas to its fuel lines and fired it up. It started prett much immediately, the engine was much quieter, but there's a tapping noise now.
    I'm not sure if this sound was always present and I didn't notice it because the cam was so loose, or if it's some slightly bent valves touching my pistons, maybe piston slap?
    If I could rotate the engine fine without any sounds before, would it make sense for the valves to be bumping pistons?
    Will a compression test or leak test let me know if this is an issue?
    80 SG Jardine 4-1
    • 9980
    Is it coming from the valve cover or somewhere else? A slight exhaust leak will sound like a tapping.
    Did you check valve clearances while you were in there.
    • jwhughes3
      • 2798
      • Home of the Alamo
      Or a weld gone bad on the inside of double walled header taps like valve noise too.
      John
      '81 XS1100H - "Enterprise"
        Or it could be the normal loudness of these engines.
        • James England
          • 3039
          • North of England
          What were the valve clearances like?
