Acceleration Issue - Bike Loses Power
  • SgtBaker
    • Aug 2012
    • 14
    *Pictures and videos posted on the first page of this thread*
    Originally posted by natemoen
    no, dielecteic grease is non conducting.
    Thanks for the clarification.
    Originally posted by GALLAECUS
    not sure where you are in Ct, but i have some items you can plug and play and see if it helps. carbs, tci's regs.coils, etc...?????
    I'm in Trumbull about to move up to Coventry. Thank you very much for your offer and willingness to help.
    Originally posted by GLoweVA
    So let me see if I got you right, you rotated/advanced the timing while the bike was running at idle?
    Yep. Apparently it was the straw that broke the camel's back for one of the pickup wires. Thank god the wire went before anything else stupid happened. You can see me doing this in the second video following repair of the wires. Thanks for letting me know that it's a bad idea.
    1980 XS-1100 SG
      • 9980
      You probably should look around for a better set of pickup coils. With that many repairs in them they probably won't stay fixed very long.
      Just sayin'
      • Gallaecus
        • May 2011
        • 254
        • East Haven Connecticut
        thats awesome, glad you fixed it. That bike looks really familiar.
        I hope the bike has been good to you....I swear I had no idea the pick up wires would fail when i sold it to you..
        I see you never put the windshield on. plz change your oil haha. do you want a trunk ? its black with a kitchen cab knob on it and black shag carpet inside.
        im not a bike mechanic hahaha
        Steven
        1981 XS 1100 LH
        1979 XS 1100 SF
        • Cobia
          • Jul 2007
          • 1587
          • Palm Beach County, Fl
          You gotta love it when a plan comes together !!!
          BTW - The pick up coil wires were also the first thing that came to mind.
          Happened to me on my G.
          1980G Standard, Restored
          Kerker 4 - 1
          850 Rear End Mod
          Automatic CCT
          1980GH Special, Restored
          '82 XJ1100 (Sold)
          • SgtBaker
            • Aug 2012
            • 14
            Just sayin'
            That's coming this winter. I noticed that the new splices have become the bending points for the wire when the unit advances, so I expect they will fail in time.
            No worries man. I expect to have to work on a 32 year old bike As for the oil change, that's coming this week. I Didn't feel good about spending the 30 dollars for oil on a bike that seemed to be getting worse. With all the tuning and maintenance I've done to it to try and fix this problem, its running fantastic now.
            The windshield was on for a while, but the light diffraction from its tiny scratches blinded me at night when approaching oncoming cars. I also have this worry that if I get thrown over my handlebars from hitting a car that pulls out in front of me, the windshield will really mess me up.
            I presented you as a "bike mechanic" because I know you're competent enough to clean and reassemble carburetors, and that you work on bikes. If I had just said "previous owner" it might have made the problem harder to target by implying amateur work.
            Lastly, I'm pretty happy with just the saddlebags. I had a trunk before and it threw off the appearance and the weight of the bike. Thanks though.
            It was good to hear from you Steve.
            1980 XS-1100 SG
              • 5058
              When I fixed one of my bikes, I extended the pickup coil wires so that I could form a loop inside the case. The short wires seem to cause more flexing and the loop made it less prone to do that. It has been working for years like that.
              • SgtBaker
                • Aug 2012
                • 14
                Thanks skids. Did you use heavier gauge wire too?
                1980 XS-1100 SG
                  • 9980
                  The wire HAS to be flexible sarge. I've heard that the lead wires for a cheap VOM work well.
                    • 5058
                    That is exactly what I used (wires from the leads of a multi-meter). The thicker gage should work because they are stranded. It just has to allow free movement of the timing plate. It gets pretty hot in there and I know that there is stranded wire that has heat resistant insulation. That would be better yet. My insulation has not melted however.
