Here again
  • x-man78
    • Jul 2012
    • 31
    • Sudbury, Ontario, Canada
    Here again
    Hey guys I was on vacation for 10 days now I m back, while I was gone I ve put new spark plug wires fuel lines and filters also jet the carbs. I also went threw all my electrical wires and they are all in good condition. So here I am all this done and I m still having the same issues any temperature higher then mid 20 s and it back fires and shuts down then a bunch of smoke comes out of the air box, 10 min later hit start and it fires up. I m so frustrated. What do you guys think that the regulator might be the problem when it heats up, on a good note while I was on vacation I picked up a 1983 xj and ran it for 2 and a half hours in the much warmer weather in southern Ontario at 35 - 40 degrees it was a great ride also confirming that my 81 shouldn't have a problem in the heat
    Thanks again
    __________________
    '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
    1179 big bore kit, 80SG motor
    Rebuilt head, valves
    TC Bros Forward Controls (Brass Pegs)
    Tkat Fork Brace
    T.C. Spade Fuse Box
    Dyna Coils & wires
    Mikesxs shocks,controls,& bars (special)
    ISO grips with stelleto ends
    4 into 1 black Bassani exhaust
    Bridgestone Spitfires
    Tuned by Tinman905
    & a will to keep it.
    83 xj 1100
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Thanks again
    The jets you put in... were they genuine mikuni?
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
    • x-man78
      • Jul 2012
      • 31
      Sorry wrong wording I adjusted them.
      __________________
      Tkat Fork Brace
      T.C. Spade Fuse Box
      Dyna Coils & wires
      Tuned by Tinman905
      83 xj 1100
      • x-man78
        • Jul 2012
        • 31
        I ve also stumbled across some info that might help with some guys givin me advice. It seems a few guys on here are familiar with my bike I bought it of a gentlemen that's a member here under the name manitoulinlad ( Dan) anyone with insight it would be great thanks
        __________________
        Tkat Fork Brace
        T.C. Spade Fuse Box
        Dyna Coils & wires
        Tuned by Tinman905
        83 xj 1100
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          How exactly did you "adjust" them..? The only thing to adjust is the idle mix screw otherwise you would have to put in different sized jets to "adjust" them...
          I think you need you be a little more detailed with your description in order for us to help...
          When does it backfire... under load during decel, any time its running or just on a cold engine..?
          When it backfires and dies what rpm does this happen? Is your idle at 1000-1200?
          Have you pulled your plugs and checked color?
          Your not giving us a lot to work with...
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
            • 2060
            And also did you clean them?Dirty carbs are dirty carbs.
            • tinman905
              • Aug 2007
              • 946
              • Orangeville,Ontario ,Canada
              Hey X-man, I rebuilt the carbs for Dan two years ago. They were tuned properly. I rode that bike on the Island just after I installed the carbs. It was a sweet ride very fast and great gas mileage too.I believe that Dan was getting 80km more to the tank after I installed the rebuilt carbs.
              Idon't think you will have to messed around too much with those carbs ,check the float heights maybe but it was running good last time I was there . I would say it's those green coils Dan installed on the bike last year. They tend to cause trouble when they heat up sometimes . I have had a few pairs now that acted up .
              Dan has removed all the connectors and went with solid connections too so maybe something there might need a good looking "at" .
              His bike also took a hit from a power surge when he had a trickle charger on it and burned out his field coil. I replaced that also.
              You're lucky I would have bought that bike if I had know it was for sale .
              BDF Special
              • x-man78
                • Jul 2012
                • 31
                Hey tinman I like the bike when it runs, it runs great. The bike idle s I think a bit high around 1500. When I said I adjusted the carbs it was just the mixture screws I went one full turn, On a cold or cool day bike runs fast and great warm weather and it stalls and back fires as for the rpm it does at a variety of rpm s and different gears you can generally feel it in the bike when it s gonna stall and I can feel the heat threw the seat.
                __________________
                Tkat Fork Brace
                T.C. Spade Fuse Box
                Dyna Coils & wires
                Tuned by Tinman905
                83 xj 1100
                • x-man78
                  • Jul 2012
                  • 31
                  Where s a good place to pick up new coils
                  __________________
                  Tkat Fork Brace
                  T.C. Spade Fuse Box
                  Dyna Coils & wires
                  Tuned by Tinman905
                  83 xj 1100
                    Check Ebay,
                    Search " dyna dc1 coil " , several for ~$125.00 a pair. They will NOT come with the plug wires. You can use the wires/caps you have, but you have to get the special metal portions that fit/crimp onto the wire end so that they can slide/plug INTO the coil towers!
                    • x-man78
                      • Jul 2012
                      • 31
                      Hey guys I wanted to run some more past ya s, the coils in the bike are new dyna coils I believe last season ( I m waiting on an email from Dan to confirm). I also I have continued riding the bike while waiting on a set, yesterday I took an after noon ride to pay a little more attention to when it shuts down it does seem to do it a little more under load but will shut down regardless I dumped half a bottle of water on the engine when it shut off and it started right away, it normally takes about 10 minutes to start again, I drove until it sut down again this time no water it took about 10 minutes to start, so I continued on my and when it sut down I dumped water again and it fired right up I did this two more times and with the same result, the water wasnt cold it was sitting in my bag all day and probaly isn't the smartest thing but hoping it shines some light
                      __________________
                      Tkat Fork Brace
                      T.C. Spade Fuse Box
                      Dyna Coils & wires
                      Tuned by Tinman905
                      83 xj 1100
                      • CaptonZap
                        • Jun 2010
                        • 1748
                        • Denver
                        Which begs the question, Where on the engine did you pour the water?
                        Have you checked valve clearances? Particularly intake valves?
                        IMWTK CZ
                        • x-man78
                          • Jul 2012
                          • 31
                          On the Top around the plugs on each side
                          __________________
                          Tkat Fork Brace
                          T.C. Spade Fuse Box
                          Dyna Coils & wires
                          Tuned by Tinman905
                          83 xj 1100
                          • CaptonZap
                            • Jun 2010
                            • 1748
                            • Denver
                            Ok, and how much clearance on the intake valves?
                            • x-man78
                              • Jul 2012
                              • 31
                              Hey guys been super busy at work lots of OT so I haven't had much time to check my bike is still having the same problems, but I have new info about the coils.....
                              Hey Wayne: With those awesome big power coils all your plugs need a larger
                              gap of .35 intead of the .30 or .32 that is stated in the manual. Those
                              coils put out way more zap & the extra gap is needed for all to run good.
                              Since you have changed out the plugs, gap them out to the .35 I should of
                              told you that b4 but just thought of it now, use the standard NGK plug that
                              states in manual *- Dan
                              -----Original Message-----
                              Sent: Tuesday, August 14, 2012 4:57 PM
                              To: 'Deanna Stalker'
                              Subject: RE:
                              Brand new about a year ago in the spring - they are high performance dyna
                              coils & wires direct from the company. Cost me around $200. They should be
                              fine & last forever - Dan
                              This the email I got so I did re gap the plugs I also did install an oil cooler just cause I was able to get one close and cheap, the only thing I haven't done is check the clearence for the valves which I m right now.
                              So my question is what should my clearence be thanks
                              __________________
                              Tkat Fork Brace
                              T.C. Spade Fuse Box
                              Dyna Coils & wires
                              Tuned by Tinman905
                              83 xj 1100
