wiring diagram
  • LuckyEddie
    • 166
    • Middleville, Michigan
    wiring diagram
    Greetings,
    Where can I get a wiring diagram for my 1980 XS1100LG?
    LuckyEddie
    1980 XS1100LG Midnight special
    1982 XV750J Virago
    1976 GL1000
    1978 GL1000 Supercharged
    1981 XV920RH (chain drive)
  • LuckyEddie
    • 166
    Rephrase question:
    I'd like a wiring diagram because I droped the motor back in after almost two years and have a couple of connectors left over and I'm scratching my head.
    One is a dark green female bullit connector that comes off the solinoid end of the starter cable.
    The other is a red/yellow male bullit connector coming out of the wiring harness above and to the rear of the tool box.
    Any help here will be greatly appreciated!
    Thanks,
    LuckyEddie
    1982 XV750J Virago
    1976 GL1000
    • Gallaecus
      • May 2011
      • 251
      • East Haven Connecticut
      you can download a copy here
      Steven
      1981 XS 1100 LH
      1979 XS 1100 SF
      • Gallaecus
        • May 2011
        • 251
        if that R/Y is paired with a Tan/Y then I'd say it is for the hazard relay
        if the green wire is tapped into the heavy black wire coming off the solenoid
        then I would say dont use it.
        Steven
        1981 XS 1100 LH
        1979 XS 1100 SF
        • GLoweVA
          • Jun 2011
          • 1957
          • Virginia Beach, VA.
          It sounds to me that the R/Y gets plugged into the green from the starter solenoid. That's the 12V that is the bypass of the ballast resistor during start.
          80G (Green paint(PO idea))
          The Green Monster
          Got him in '04.
          bald tire & borrowing parts
          Scarlet
          Got her in '11
          Ready for the twisties!
          81H (previously CPMaynard's)
          Hugo
          Cold weather ride
          • Gallaecus
            • May 2011
            • 251
            that seems to make sense George. I recently came across that green wire but I didnt use it. I must have an 81 harness that did not have the two R/W wires for the ballast so I used coils with 3 ohms across the primary. and I probably have an 80 solenoid with the green wire, and IIRC the wires to the TCI were missing those red wires that are shown in the schematics. so I am assuming that my clymer manual does not have the latest diagram of the 81 SH harness.
            but it does show the R/Y wire from the TCI tying into the starter side of the solenoid.
            I knew I wasnt the best source of information on this one.
            Let us know how you make out Eddie
            Steven
            1981 XS 1100 LH
            1979 XS 1100 SF
            • LuckyEddie
              • 166
              Time will tell...
              Thanks Guy's for the input.
              I too was leaning in the direction that they get pluged together, It just goes against my instincts to plug two wires together that are different colors.
              LuckyEddie
              1982 XV750J Virago
              1976 GL1000
              • LuckyEddie
                • 166
                I wonder......
                I wonder if there is anyone out there with a 1980 XS1100LG that would be willing to have a look at their wiring and confirm plugging those dissimilar wires together??
                LuckyEddie
                1982 XV750J Virago
                1976 GL1000
                • Gallaecus
                  • May 2011
                  • 251
                  definitely a red/yellow wire plugged into the green wire on my 79 special
                  and I did not wire this bike
                  Steven
                  1981 XS 1100 LH
                  1979 XS 1100 SF
                  • LuckyEddie
                    • 166
                    Thanks
                    Steven,
                    Thanks very much for the pic confirming wire connection.
                    It is a good thing to have documentation of such a goofball connection.
                    LuckyEddie
                    1982 XV750J Virago
                    1976 GL1000
