final drive question
  • Nightengale
    • Jun 2011
    • 521
    • Hampton, VA.
    i was cleaning my bike yesterday and noticed that my final drive was leaking final drive oil out of the filler plug , and mine was alittle beat up, so i was wondering if anyone knew where i clould find a new one . here is a pic of it
    xs1100 hartail bobber
    http://i1169.photobucket.com/albums/...-38-36_563.jpg
    Yamaha dealer, bring this part number with you, 90340-14046-00, or order it online. The part number for the crush washer is 214-11198-01-00, or use a washer off a spark plug.
      Hey John,
      That bolt is pretty much worn out...the allen head fitting, you might also want to look into getting a replacement....folks have gotten ones with hex heads for easier loosening and retightening, and a NYLON washer(yeah, that's what I meant, thanks skids) also can be a good seal. I'm thinking there's a tech tip that tells the thread size/pitch for that hole.
        • 5073
        Use a nylon washer. It is the very best way of preventing headaches down the road!
        • jwhughes3
          • 2798
          • Home of the Alamo
          I think threads match a spark plug I was told.
          John
          '81 XS1100H - "Enterprise"
          • jayel
            • Apr 2012
            • 152
            • Birmingham, Iowa
            here are a couple options I found by google 14mm x 1.25 drain plug
            SUZUKI 09248-10007 14mm x 1.25mm Magnetic oil drain plug head size=14mm
            Ford Diesel - 14mm x 1.25 x 21mm - Magnetic Drain Bolt Fits 94-04 Ford Diesel Power Stroke.
            where are we going, and why are we in this hand basket?
            Iowa the Beautiful Land 1980 XS1100SG
            • Shacknasty
              • Feb 2011
              • 379
              • SFV-SoCal
              If yer leakin' outta the filler hole then ya prolly have too much gear oil in the FD. But ya still wanna change out that beat-lookin' plug!
              • mlew
                • Jun 2005
                • 226
                • Apex , NC
                Most auto parts stores have hex head drain plugs 14mmx1.25 with a new washer for 4$ or less. I have them on mine makes oil changes easier.
                Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
                Current rides:
                80 XS1100SG
                82 JX1100
                83 Venture Royale
                86 V-Max
                • Nightengale
                  • Jun 2011
                  • 521
                  • Hampton, VA.
                  i dont think so
                  i dont think that it has too much gear oil, i think it is coming out there because of the bumpy interstate here, and my bike does have a hardtail.
                  • Shacknasty
                    • Feb 2011
                    • 379
                    • SFV-SoCal
                    To quote Emily Latella, "Never mind."
                    • Nightengale
                      • Jun 2011
                      • 521
                      • Hampton, VA.
                      thanks guys
                      just wanted to thank everyone for the help i am gonna get a new one at the auto parts store tomorow
                      • jayel
                        • Apr 2012
                        • 152
                        • Birmingham, Iowa
                        just checked it is NOT 1.25 (sparkplug thread) must be M14x1.5
                        • jwhughes3
                          • 2798
                          • Home of the Alamo
                          Please post when exact thread is found.
                          It was mentioned at MoM Rally that a spark plug would work. Maybe it had been forced in?
                          Thanks
                          John
                          • jayel
                            • Apr 2012
                            • 152
                            • Birmingham, Iowa
                            I just welded a nut to the tops of mine works well and cheap
                            • jwhughes3
                              • 2798
                              • Home of the Alamo
                              Well thats an idea.
                              John
