Lithium battery?
JCarltonRiggs
79XS1100F; ?Parts?, or to Restore? -
If you add the right oil to the R/R it won't heat up so much, but then what is the right oil?
OH NO! Another thread about the right oil!!! DAMHKID?!$&whathaveistarted?!
I thought this thread had gone off to die the quiet death of an interwebs site gone unpaid, but here it is again?! I am extremely tempted to slap on a car alternator and tiny bike battery too at this point. If running a car alt, which being regulated internally to not overvolt/overcharge the battery, would it then be safe to use one of the lithium batteries?
Oh crap, here we go again...BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
80 XS1100SG(cafe in progress *slowly)Comment
Hey Davey,
You mean like this!
I just reviewed the stats/specs on my Mini Race Alt....as you can see the voltage is set a bit high...~14.90, so I think it would be too high for a lithium!
So....you might need a special circuit to keep the charging voltage from going too high no matter which system or regulator you use!
T.C.T. C. Gresham
Exactly like that! Or I was thinking maybe a very small automotive unit. That thing is pretty tiny, but next time I'm at the local junkyard I'll take a tape measure and run around a few different cars to see what I can find. If you changed the pulley sizes around maybe you could "tune" it to never go over 12v at redline... But then it probably wouldn't make 12v until halfway up the revs either. I'd be very tempted to pay for a small digital voltmeter to have you wire it in and get me some real bike specific numbers on your setup, see if it ever goes up to 14.9 or if it's paper is just exaggerating slightly. Seems like that would greatly simplify the charging system, and probably not add back much, if any weight. (That factory rotor and stator is a bear!) and it also shouldn't change the parasitic loss to the engine much, if any, either. Hmmm... Time to go junkyard hoppin and then off to the metal recyclers to find a piece of plate...BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
Hey Davey,
Here's the Megathread on this project!
I have a cheap voltmeter on the dash, but it's just led lights at the whole volt indicator marks. It does run around 14 volts, but does drop a bit when I have the AUX lights on!! But the gauge isn't that accurate, so I can't tell if it's gone much to the 14.5 to 15.0 volt range. I got it mostly to show me that it's at least providing the charge needed to keep the battery going, and not at the 12 or less discharge level!
I took some more accurate voltage meter readings while it was running, but just on the centerstand, see the photos in the thread...which I still need to make into a TECH TIP!
The other option that was discussed was trying to fit the center rotor shaft onto the cranshaft so that a newer style ALT asembly could be mounted to the engine where the OEM one is but the problem of securing the ALT housing, actually affixing the alt rotor/shaft to the crankshaft was problematic. The pulley/belt seemed the easier mounting and isolation technique, same size pulleys kept the tach signal the same and the alt within the RPM range for both optimum output without going overboard on the rpm's into the 10k+ range!
T.C.T. C. Gresham
I have just put a lithium battery on my XJR1300. Stock battery weighed over 9 pounds. The lithium weighs just over 2 pounds and is tiny! It works better than the stock one. Faster starting. No problems whatsoever. Id recommend them.......
Ive been 'off line' for a while guys but havent forgotten you all!!! Had a few issues. Now resolved so......hope I'm welcome back to the fold. Heres the XJR these days... I just replaced every single fastener with TITANIUM..... a huge saving in weight!
Wheels are forged alloy Galespeed...almost 50% lighter than stock......
XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
I'm wondering if the lithium battery may be more compatible with the XJR'sI have just put a lithium battery on my XJR1300. Stock battery weighed over 9 pounds. The lithium weighs just over 2 pounds and is tiny! It works better than the stock one. Faster starting. No problems whatsoever. Id recommend them.......
charging system (than the XS11)~~ being as the stator, field coil, and R/R (rectifier and regulator) setup (on the XJR) is different ~~ in fact, even being Mofset technology compatible?JCarltonRiggs
79XS1100F; ?Parts?, or to Restore?Comment
I think this is getting over thought a bit. A field current regulated charging system should be infinitely more desirable than a shunted fixed rate system. I suppose the fixed este systems are used because they are light, simple, and cheap.
I would stake the cost of a lithium iron phosphate battery that you could drop one in the xs11, with no other changes, and it would work just fine. Most of the confusion here was over my assumption that the xs11 used a shunt type regulator like the xs650 does, in which case the MOSFET regulator would have been an improvement. As it is, I think the 11's stock system is regulated in a superior way, and will work with the lightweight battery just fine.
I don't have an 11 to try it on, though...Healthy is merely the slowest rate at which you can die
Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. ThompsonComment
Hmmm... Maybe I will buy one then. Along with a large gauge quick disconnect plug... And a small fire extinguisher... And try it out, see if it works!BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
Welcome back James...was beginning to wonder what happened to you. Glad Newgate is behind you :O !
XJR is looking sweet. I can see why its siren song stole you away from the XS. Like a hot, sexy, new secretary - easy to spend time and money on because she makes you feel younger and more powerful. But coming home to the old XS girl somehow "feels right" and makes you happy inside. Time for another XS my friend.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
That would also be alot of current to SHUNT to ground.
