Damn Diaphragms
    Damn Diaphragms
    Anyone know a trick to getting stuck diaphragms loose from the slides? All I've ever tried came out fairly easy, Ive got a set that won;t turn loose though.
    Hey Greg,
    You've got me confused? Are you trying to separate the rubber diaphragms from the metal slides....or are you using the wrong terminology and are trying to get some SLIDES out of the carb bodies, but they are stuck in the carb bores????
      Trying to get the rubber off the slides.
      As I said, usually, with a little effort, I can pull them free from the groove in the plastic piece at the top of the slide but these won't budge.
        I thought the plastic portion CLAMPED onto the rubber diaphragm, so that they should not be easily removed?? I remember seeing Toolmaker Tim's post about replacing the damaged diaphragms on a set, and I thought he had to CUT the plastic part off of the slide.
        Is this on the early year slides, or the later series??
          Do a search. Someone posted a "how to" on that subject.
            I am rying to put the rubber from a set from a 79 on a set of slides from an 80. The 79 rubber pulls out and is reinstalled easily on early slides but the carbs for the 80 have been sitting for about 10 years. I got the carbs themselves cleaned up but the diaphragms are like looking through a screen door when you hold them up to the light.
            • red bandit
              • 970
              • central michigan
              The slides from a 79 are different diameter than the 80's. I don't think they will fit.
              79 SF parts bike.
                Yes, the slides are different but the diaphragms ar the same size as far as I can tell.
                  OK. Found the thread.
                  Funny that the eary carbs you can swap them around but the later ones you can't.
                  Trying REALLY hard not to say anything bad about EPA or Nader.
                  • tarzan
                    • 1700
                    • Chandler,Az.
                    Hey Greg,
                    You may be trying to save some coin, and you may know this, but you can buy new diaphragms for $20 each. They are super easy to install also. I bought some from here http://www.jbmindustries.com/JBM_ORDER.html.
                    You do have to cut the plastic rings off to install the ones from JBM. though.
                    80 SG XS1100
                    14 Victory Cross Country
                      Thanks, I found those last night. It's not my bike, I'm just trying to get it going for him on the cheap.
                      May have to go that way.
