Caliper pistons
  • mack
    • 2411
    • Ontario, Canada
    Caliper pistons
    What's. The source for special ss caliber pistons?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    HVC Cycle
    Ebay search XS1100 caliper piston and it will come right up.
    • mikubuilder
      • Jul 2011
      • 548
      • Westland, Mich.
      try this place:
      and they have boot kits, too.
      Nick
      1982 Virago 750 (it's alive!)
        I was briefly looking at their website and didn't see them, but found them on ebay right away.
        I always like businesses websites rather than ebay cause it is usually cheaper.
        • mack
          • 2411
          • Ontario, Canada
          Rear caliper
          Anyone remember what the size of the rear caliper piston is on an SF?
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
            Do not the size right off Mack, but, all the rear calipers are the same size. Ok, with the possible exception of the XJ and the LH.
            • gtem
              • May 2023
              • 235
              • Indianapolis
              Digging up an old thread: I need to replace the pitted rear piston on my '79 XS1100F... brakecrafters (who I have used for a friend's MS rear caliper rebuild) only lists a rear piston for Special rears, or standard fronts. Is the MS rear the same as a standard rear by any chance? Thank you.
              Looks like I need a 38mm OD piston?
              EDIT: Answered my own question with a very useful post from Steve:
              '98 GSF1200S '81 GS850G
                Here's what I found, scroll down to the Product Fitment section to cross reference. Curiously they don't list the 79F even though the part number is shown on the 79F parts fische.
                https://www.partzilla.com/product/ya...J3-W0047-00-00
                • gtem
                  • May 2023
                  • 235
                  • Indianapolis
                  Thanks LAB3, in this case I need the actual piston as it turns out mine is horribly pitted! I had initially hoped I could still use it (the pitting would be out of the range of where the seal travels) but the caliper started to stick after some riding this spring. Also my rebuilt (but also pitted bore) master cylinder woes are back, thankfully I have a spare to try swapping over.
                    I've had plenty of success over the years polishing old pistons with 600 grit paper followed by 1500.
                      Yamaha XS1100 F 1979 rear brake caliper stainless steel piston | eBay
                        Stainless pistons are much better than stock. Keep that brake fluid clean by flushing every two years.
ID:	884256 Click image for larger version
ID:	884257 Click image for larger version
ID:	884258 Click image for larger version
ID:	884259 Click image for larger version
                          • 3193
                          XJ4Ever.com can hook you up with many of the parts on our Xs1100's. The brake caliper pistons are listed along with size measurements and year of fitment. The catalogue is kind of a pain to use but there is a virtual myriad of parts available.
                            • 3193
                            https://www.ebay.com/itm/22359227531...3ABFBMkJPAvrxl will find the SS for the front brakes. Rear is a different size.
