Carb?
  • ifthis
    • Jul 2012
    • 2
    • Miami, Fla.
    Carb?
    I'm thinking sticky float.
    Bike runs great. Until I let off the gas. It will sit at 3k rpm for a second and drop to 1k. And be fine. If I hit the throttle before that she will piss and mown. Strong gas smell. Half power and back fires.
    The bike history
    P.o picked it up for 900 in Seattle. Took it to Alaska and down to key west. Problem started on the way from key west to ft lauderdale Everything else butchered on the bike was a " just get it there" fix I do the same.
    My history being first post
    Vespa up down east coast, western europ 1 carb is easy.
    Cx 10k ish once a year trip 2 carbs if seafome can't fix. New bike time.
    80 XS11
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    I dont have any fix for your problem. Just wanted to say that youre going to be oing through a ton of bikes if youre not willing to do more than Seafoam to them.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    • mack
      • 2411
      • Ontario, Canada
      Welcome
      Could be a number of things, but pulling the carbs off and cleaning them inside and out won't be a waste of your time. Make sure the butterfly shafts moves freely and snaps closed all the way to the idle screw before you reinstall. By the sounds of it, this would also be a good time to investigate all the emergency repairs and make them more permanent.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • tweeleft
        • May 2009
        • 110
        • Bend Oregon
        Can we ask "When was the last carb sync done?". Idle Mixture?
        Keep the shiny side up
        1979 XS1100SF
        Mac 4-1
        Drilled airbox Uni filter
        Vmax bars
        Virago 1" shorter shocks
        30K miles
        http://i1228.photobucket.com/albums/...429_135845.jpg
        1981XS1100SH
        '80 G Forks and Triple Tree
        '80 G tank
        Mac Turnouts
        Virago 1" shorter rear shocks
        SH Headlight
        http://i1228.photobucket.com/albums/...psd6adaae1.jpg
        61 Wife
        83 Son
        86 Son
        89 Daughter
          +1!!! If seafoam is your only tool than buy a newer bike.
          You are going to have to open up and clean the carbs manually.
          • ifthis
            • Jul 2012
            • 2
            • Miami, Fla.
            seafome and a #2 screw driver
            I was hoping for an electric problem , post owner said they were done, 5k ago. Mabey by the same guy that cut every hose and wire to make it run. and forgot the filters.
            Carbs will come off. I talked my mechanic up to 20 to take them off. Have to talk him down to put them back on. 20$ save an hour in the sun. Good deal.
            I'm not qualified to sync them, but there seems to be enough info on hear to figure it out.
            thanks
            80 XS11
              thanks
              We can talk the most mechanically inept through as ling as they are willing to listen and follow directions.
              Go though this thread and you can clean them yourself. For the cost of a few cans of spray carb cleaner.
              • mack
                • 2411
                • Ontario, Canada
                Carbs
                Like Nat said, you should do them yourself. If your going to own and ride one of these big dudes, knowing your carbs is a must.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
