Louder Exhaust
  • Louder Exhaust
    Hi.
    I have a Jardine 4-1 megaphone exhaust.
    I would like it louder than it is... any suggestions?
    Thanks.
    '80 XS1100 SG <== now parting post 45mph wreck
    '79 Jeep CJ7, my other lover and drain of cash...
    i have a 4-1 kerker on my xj. it has a removeable cone at the back side. it has no packing in it. it is real loud when you crack the throtle. not sure about jardine,might have same removeable set up.
    1982 XJ 1100
      when my stock exhaust was about dead
      in order to balence the back pressure
      I took and drilled about 6 to 8 holes in a circle at the
      end of the megaphone on each side
      made a difference in sound
      but didn't make it thru an inspection
      but it did get me thru a season
      http://home.securespeed.us/~xswilly/
      79F Parts
      80G Parts
      75 DT 400B enduro
        My old 4-1 pipes I got from JCW over a decade ago(they no longer sell them for the XS11) had a rather tinny sound. They only had a crimped baffle pipe welded to the the end of the megaphone seal plate, and it could be removed by unbolting it. There was NO glass packing, etc inside the megaphone. I drilled only 4 1/4" diameter holes in the megaphone seal plate and it gave it a nicer deeper throat. And, if I have any problems or concerns about inspection, since I can remove the plate to get access to both sides of it, I can either screw in some sheet metal screws into the holes, or put some simple nut/bolt combos to "temporarily" seal the holes until after it passes, then just remove them to get the sound back!!
        T.C. 'ping,ping,....er...I mean.....VROOM, VROOM!!
          The Jardine 4-1 has a cone baffle on the end that can be removed for louder sound. Mine is attached by two pop rivets side by side at the bottom. Just drill those out, it's only a friction fit on the other side. The rivets on mine worked loose enough that it occasionally blows out when I really crack the throttle.
          Robert
          79 SF
            Robert,
            How does it sound without that cone baffle?
              I've ran The Dark Horse with the baffle removed for short periods of time. (Sounds like a race car in my garage. ) I've not ran it on the road that way. I had concerns about performance problems or burning exhaust valves, etc. by doing this.
              What do you XS Guru's say about this?
              Bob Udy
                mine sounds real deep and throaty.quiet nice i might add.louder than most harleys yetnot loud enogh for a ticket.
                1982 XJ 1100
                  Originally posted by sam_cg_cook
                  Robert,
                  It's a louder/deeper rumble. Ususally the way I find out the baffle has come off is that I'll notice that the engine is sounding particularly "bad ass". When I look at the exhaust, sure enough the baffle is hanging off. I like that sound, that's why I went to a 4-1 header from the stock pipes. But since the baffle finishes the end of the pipe, I choose the looks with it on over the sound with it off.
                  Robert
                  79 SF
                    Thanks... I think that I'll go for the sound.
                      Why would anyone want it louder????
                      Ron Moss
                      1979 xs 1100 yamaha special (sold)
                      1984 honda v65 magna (sold)
                      1984 vtr 250 intercepter
                      1975 250 TL Honda
                      2006 Kawsaki Concours
                      1979 R100RT BMW
                        So the 94 year old white hair with the broken hearing air in the land yacht in the lane to your right that is about to turn left might just notice you,
                        • #13
                          I have a Jardine 4 into 2 turn out drags on mine and it is plenty loud. and best of all they look cool and sound cool..
                          Madness comes from within.
                          78 XS 1100 E (at Birth) "Madness"
                          79 XS1100 parts bike "hunk of junk"
                          83 Sportster "Lunacy"
                          72 Shovel "Dark Shovel"
                          • #14
                            In addition to enjoying the aural sensation of combustion/power, it can also be safer. My stock pipes are so quiet I have had people in cars and even bikes tell me that they didn't know I was there as I pulled up next to them. A louder pipe can give warning (esp. to cages) that you are nearby so they can be watching out for you. Hence the expression "loud pipes save lives". The quicker the bike the more important this can be, and our bikes are quick.
                            Robert
                            79 SF
                            • #15
                              I won't argue the pros and cons of noisy pipes ( it's like a helment or oil thread) but I will say I believe loud pipes piss off more people than they impress. That said I have ridden daily since 1965 and have never wanted to impair my hearing or comfort while riding. My thoughts on the matter.
                              Ron Moss
                              1975 250 TL Honda
                              1979 R100RT BMW
