Painting pipes
  • haywardguy929
    • Jul 2012
    • 345
    • Hayward, Wisconsin
    Painting pipes
    I'm seriously considering this and found some tips I thought I would pass on,if anyone esle has done this and can add anything I'd appreciate it,thanks.
    Instructions
    1
    Use a wire brush and a cleaning product, such as paint thinner, to remove dirt and grease. Sand the pipe lightly. With latex gloves on, wipe the surface with thinner once again. Use tape and newspaper to mask off anything you don't want painted.
    2
    Buy paint that resists high heat, such as PJ1 high-temp paint. You can find spray cans of it on websites and at auto parts stores. You also can use flat black paint made for barbecue grills--it's available at many hardware stores. Spray on several light coats, letting them dry in between.
    Sponsored Links
    Try Corel PaintShop Pro
    Get Corel's Latest Photo-Editing Suite. Try It For Free Today!
    Corel.com
    3
    At the end, warm up your bike for about 15 minutes. Let it cool, and warm it up again for about a half-hour. This slow warming process helps the paint cure.
    4
    After painting, use header or heat wrap on the first 6 inches or so. Even high-temperature paint will peel near the engine, and wrapping makes it look better. The wrap is available at hot rod shops.
    400 grit for sure. then go over the entire pipe with a Red 3/M scotch pad with adjax , yes I said ajax with a littl bit of water. This will make sure you get all the grease and oil off the pipes. The most important part is do all of this while wearing rubber cloves. Otherwise everywhere you have touched these sanded down pipes with your bare hands the oil from them alone can soak into the open pores and cause major Fish Eye. And ya might want to also check paint from VHT for Headers might give you a better finish.
    Ive been using Rustoleum High Temp Barbeque/Grill paint. It works very well. I have found that when painting an exhaust it seems to help if you let it cure for 3 or 4 days before starting the engine it doesnt turn "dull" as fast.
    That stuff or the PJ1 paint. If you heat it lightly several times and let it cool off, rather than just cooking the poo out of it, it will stay on. I used to touch up my flat black header on my SR500 occasionally, let it cure overnight, then started it up the next day, let it run until too hot to touch, turned it off, repeated several times. Then it would stay on. Pipe must be properly prepped or nothing will make it stick. Wipe down with starting fluid on a rag as the last step before paint, it gets all the residue off.
    81 H
    I would say no to the bbq paint. It fades and gets chalky quick.
    • mikubuilder
      • Jul 2011
      • 548
      • Westland, Mich.
      is there a fake chrome paint that will stick to the pipes? I need to paint mine, and I don't want black...
      Nick
      1982 Virago 750 (it's alive!)
      • jwhughes3
        • 2798
        • Home of the Alamo
        There is ceramic high temp in silver.
        Anyone know how to fill gouges in pipes? I know bondo and epoxy arent going to hold up to the heat. I wonder if melting lead and sanding smooth. Dont know if it will stick though.
        John
        '81 XS1100H - "Enterprise"
        • CaptonZap
          • Jun 2010
          • 1748
          • Denver
          Cerma Chrome, a powder coating, gives a fairly decent imitation of chrome, and on a double wall pipe, (stock Yamaha), would last fairly well. If on a single wall pipe, it will dull near the head ports after a while, due to heat.
          Solder, (lead and/or tin) will not stand up to the heat involved in an exhaust pipe. Brass, (brazing), would do the trick, but requires a deft touch with a torch so as not to deform the surrounding metal. Plus the grinding, filing, sanding, etc that would be necessary to get to the smooth state required for the CermaChrome application.
          There are other companies doing comperable stuff, located around the country. Bing or Google is your friend in such a situation.
            I think it is called Lab Metal, it is a metal based bondo that can withstand curing temps.
            • haywardguy929
              • Jul 2012
              • 345
              Looks like good stuff.
              I've also been touching up my bars,bags and tank with a little appliance touch up paint and happy with the results. A little steel wool has helped too for light surface rusts. Thanks everyone for your advice and input.
              81 H
