80G Fork question
    Originally posted by skids
    The air-assist is bunk anyway. You don't need it. This was another fad like oil coolers for air-cooled engines.
    Seriously Sid?..............U must be havin' a bad day.......sorry...
      BTW, your ST has an oil cooler too, which I'm sure doesn't attribute to them being 300,000mi. motors.......just sayin...
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        Okay, been doing some research on this and here's what I've found so far.
        The Standards (80-81) have a 14mm valve on them. PN: 3H5-23190-00-00
        These are No Longer Available (NLA)
        The Specials (80-81) have a 10mm valve on them. PN: 5K7-23190-00-00
        These are still available and are found on quite a few bikes up to '95. (allmost $30)
        (You can see the different size bolt heads in my pics in my 9th post in this thread)
        Crazy Steve says that the thread size is different between the standard and the special, so no joy using the SG's. (I am going to verify this to be certain)
        I did find a very old thread here that said the Suzuki GS1100 (80-83) PN: 51293-49001 is the exact part and it worked for a fellow member.
        These are still available at about $15.
        So my search begins for a Suzuki air valve..... Unless someone here wants to donate one for a G(H) to me cheap.
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
          • 8766
          George, I may have an extra air valve laying around for the Standard forks. I sent one to another member not too long ago and probably have another, I'll check for you.
            • 8766
            Sorry bro, I only have the smaller type for the Special forks which won't help you.
            • DCracer25
              • Jul 2011
              • 179
              • harpursville NY
              forks
              I have the complete air assist forks setup for a 81 standard or venture as they call it, needs new seals also would throw in the calipers and brakes even a front fender if you want them for 75.00 plus shipping.
              • WSL91
                • Feb 2012
                • 427
                • Quad Cities, IL
                Is there a chance that someone mixed up the caps? Lost the original? Maybe just a cap? Maybe a hens tooth?
                1970? Honda Z50... gone
                1974 Honda CB200... gone
                2008 Honda VTX 1800F
                http://www.johnsoldiron.com
                • GLoweVA
                  • Jun 2011
                  • 1957
                  I won't know for sure until I get them apart and verify the springs in there.
                  Phil, thanks for looking.
                  DCracer25, Thanks for the offer, but my forks are okay, just a leaky seal. I've had the new seals sitting on my shelf for about 6 months, just waiting for an opportunity and enough bravado to get it done.
                  The Green Monster
                  Got him in '04.
                  Scarlet
                  Got her in '11
                  Hugo
                  Cold weather ride
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    Update
                    So, I ended up getting a GS1100 valve for cheap on fleabay.
                    It threaded in just fine into the G forks, but like the previous pics, it's a 10mm nut size like the SG.
                    So on the right side, I've got the bigger looking 14mm size and on the right the 10mm one.
                    The right side one has the original valve cover/cap which covers the entire thing. (sorry no pic) while the available caps for the smaller SG ones are just like a metal tire air valve cap. (with a slot for a screwdriver on the top)
                    I don't have a cap right now, so I just used a plastic valve cap to keep the debris out.
                    Now it's time to get the fork seal changed out so I can put some pressure in these forks and hopefully ease up my ride a little.
                    The Green Monster
                    Got him in '04.
                    Scarlet
                    Got her in '11
                    Hugo
                    Cold weather ride
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      Found a pic.
                      You can see how the whole cap covers the entire air valve.
                      Where as the SG caps are different:
                      This one is for a XZ550RK VISION 1983, but is the same shape.
                      The Green Monster
                      Got him in '04.
                      Scarlet
                      Got her in '11
                      Hugo
                      Cold weather ride
                        That last pic. is what comes on the 81 Venturer in chrome.
                        • Rasputin
                          • 3189
                          • Lacombe, Alberta, Canada
                          George, I believe that you have either measured wrong or my parts bike is wrong. The ones on my G are 12mm. I am not 100% sure they are original either.
                          I think that the forks have not been disturbed for some time. That does not mean that the fork caps have not been changed.
                          Here are some pics of what I have:
                          Yours for a simple PM of your address if they are right for you. If they do not appear right then they may live a long and happy life in my garage.
                          2-79 XS1100 SF
                          2-78 XS1100 E Best bike Ever
                          • GLoweVA
                            • Jun 2011
                            • 1957
                            Yep. The G & H were the only ones to get the 14mm nut and the chrome cover.
                            Though it looks like there may be some black ones for some later models.
                            The Green Monster
                            Got him in '04.
                            Scarlet
                            Got her in '11
                            Hugo
                            Cold weather ride
                            • GLoweVA
                              • Jun 2011
                              • 1957
                              Oops! Maybe they are 12mm. I'll measure again in the morning.
                              The Green Monster
                              Got him in '04.
                              Scarlet
                              Got her in '11
                              Hugo
                              Cold weather ride
                              • Rasputin
                                • 3189
                                Like I said if they are the right ones I will send them to you. If not then they stay here for the time being. If I am correct send me a PM and they will be 10 to 14 days to get to you.
                                2-79 XS1100 SF
