High speed crap out
  • Sicko
    • Jan 2012
    • 7
    • Hurricane, UTAH
    High speed crap out
    On a ride last week my Xs11 died for not reason... or I thought. Turned out that the recitfier went bad. The shop put in a new rectifer but now I have a differant problem.... At low speed the bike runs fine. Even winding it up tight, but when I get on the highway and punch it the moter sees to loose all power. basically it's running only on a couple of cylenderes. When I lket off the throttle a little it some times backfires. I live in southern Utah and it's hot but I don't think its a vapor lock issue. I was wondering if it could be a coil? Help please.
    SICKO!!
    1981 XS1100 SH
    Cafe Racer
    Sounds suspiciously like you have a bad pickupcoil wire. Under the left engine cover.
      • 3193
      +1 on BA80's advice here.
      • Sicko
        • Jan 2012
        • 7
        • Hurricane, UTAH
        Thanks guys. I pulled on the wires of the pick up coil and there was no differance. It runs fine at our normal highway speed ... 55 - 60 mph. It's when I get it on the freeway where I need to punch it up to 75 - 80 mph. It will all of a sudden backfire if I let off on it even a little, then it acts like I fuel starved or something. Thought maybe even maybe the coils.
        SICKO!!
        1981 XS1100 SH
        Cafe Racer
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          Might have a blocked gas tank cap vent... But usually the bike will die because it becomes vapor locked. You can check it by riding it with the cap open, go give it a wack on the freeway and see if it happens again. Otherwise the symptoms fit for broken puck-up wires...
          Did you try flexing the wires under the cover while the bike was at idle?
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
            As BA80 stated, you STILL have a bad pick-up wire under that left cover. Can't just pull on them quickly and call it good to go, have to use both hands so u can pull in inch incriments to see if plastic sheaving stretches like gum to find a break.
            • Cuda 69
              • Jan 2012
              • 676
              • Greenwich N.Y.
              +1 what motoman says you have to check it carefully.I had the same problem.
              FOXS-XS11SG
              1980 XS11SG-sold
              1999 Vulcan classic-sold
              1982 XJ 650-sold
