High idle on choke
  • dug mare
    • 7
    High idle on choke
    82 XJ1100 revs high (3000-4000 rpm) when started on choke. I find this troubling as I really don't like to run a cold engine at these rpms. Is there an adjustment that can help this problem?
    XJ1100
    https://lh5.googleusercontent.com/XE...=w1201-h677-no
    82 SR500
    74 Yam MX250
    80 XS750 Dirt Tracker
    72 XS650
    other to be posted later
    • 8077
    Do you have to use the choke to start it?
    • DAVINCI
      • Jan 2011
      • 1048
      • Cedar Mountain, NC
      try less choke!?
        If it runs that high on full choke, like Davinci said, start is with half choke. If even half causes that problem, then I am interested in how it runs on no choke when it is warmed up, a little rich?
        • haywardguy929
          • Jul 2012
          • 345
          • Hayward, Wisconsin
          I find using the half choke for a few minutes works best,just a minute or two.
          They seem a little cold blooded. Within a half a block I turn it off and it idles nice for me.
          81 H
          • ddragon63
            • Jan 2012
            • 1101
            • Ridgefield, WA
            My Full Choke use to rev to 4000... it would start about 2500, then after about 30 seconds would climb to 4000. After I synced and tuned the carbs this went away. now full choke is about 2500 half choke is about 2000. My carbs weren't badly out of syn but air fuel mixture was way off on 2 of them... JAT
            Don
            old:
            1989 kawi ex500
            1996 yzf-r6
            1999 yzf-r1
            2001 kawi zx-6r
            2000 Ducati 748
            2002 YZF-R1
            2005 V-Star 1100 Classic
            • Zeke on Wheels
              • Jun 2012
              • 38
              • Frederic, Mi.
              My 80SG will work itself up to around 3-4 after about 4-5 minutes, if left unchecked.
              Since I switched to 87 octane for the last 2 tanks, it seems like warmed up idle is 1500RPM. Isn't that a little high? My last tank did give me 43MPG too!
              80 XS1100 SG "Iron Horse"
                • 5073
                Yeah, a little high. Idle should be just a hair over 1000 rpms or your gears are going to feel it when you shift from neutral to first.
