ZEP Rust Calcium Stain remover
  • ViperRon
    • Feb 2011
    • 1062
    • Woodstock, VA
    I had put off for a while cleaning my tank as it was just surface rust not large pits. I thought I'd see just how well ZEP works and it works great. After sealling off all holes I poured 1 small container (its less than a quart) in and wisked it arround all over the tank. I then poured about 3 gallons of water in put the plug in and let sit over night and the next day was pleased to see bright shinny metal where the chemical had set. Next night flipped it and same procedure and now entire tank is bright and clean.
    Tank cleaning for less than $6.00 from LOWES, no damage to paint on outside or anything. However I was careful and had no spills.
    So if you have been putting it off in fear, don't its easy.
    Rodan
    1980 G Silverbird
    1198 Overbore kit
    Grizzly 660 ACCT
    Barnett Clutch Springs
    R1 Clutch Fiber Plates
    122.5 Main Jets
    ACCT Mod
    Mac 4-2 Flare Tips
    Antivibe Bar ends
    Rear trunk add-on
  • MPittma100
    • Aug 2011
    • 2359
    Rust Remover
    Sounds like a good fix. How did you get all the water out afterwards?
    MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      After I rinsed several times I blew it out and put a old can of dry gas which is basically alcohol opened all holes drained and hit it with compressor and set it in sun. It was 101 today so after about 30 minutes it was dry. Did not see any flash rust but leaving over night checking tomorrow. If I see any I'll probably do a quick rinse with Phosphoric acid to get a coating on it. I had washed once several years ago with phosphoric but it did not clean as well as I wanted. The diluted ZEP appears to have cleaned it much better.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • MPittma100
        • Aug 2011
        • 2359
        Rusty Tanks
        I have previously used coatings for gas tanks where you slosh it around coating the interior surface. Let it dry and you are good to go. Works good for rust or porosity or for preventing corrosion characteristics of certain fuels.
        When I use aluminum tanks in race cars running methanol, the tanks have to have this coating to prevent the reaction from the fuel to the aluminum.
        MP
        K&N Air Filter
        ACCT
        EBC Front Rotors
        Mike
