Stock ignition and plug gap question
  • XSive Okie
    • Jun 2010
    • 281
    • Enid, OK
    I used the search function and didn't come across the answer I was looking for. Will the stock ignition handle a .035 plug gap? Or should I stay in the recommended .028-.032 range?
    Richard
    '79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
    '02 Honda VTX1800C
  • jwhughes3
    • 2798
    • Home of the Alamo
    Maybe....
    Voltage is needed to overcome the gap so a larger gap = more voltage needed.
    Are the 30+ year old components up to the task or will you misfire?
    When the gap goes up, spark duration decreases. (Higher voltage means less duration - its a fixed formula) The wider the gap means more likely there will be some flammable mixture near the wider area to be ignited - the longer duration of a smaller gap the more chance to find some to ignite. A leaner mixture will have more areas with insufficient flammable mixture, resulting in a lean misfire with a wider gap.
    Forcing the coils to push higher voltages will necessarily cause secondary effects on insulation and the like - it all won't last as long. But in the interests of peak performance sometimes that is a sacrifice we make in longevity for the last ounce of horsepower.
    I am not saying .035 won't work I am sure it will run - just that the recommended spark gap is determined by a multitude of factors - I have a whole book on the design and tuning of competition engines that I bought back in Engineering School - it made my head hurt and I switched to Nursing instead Now I am lucky to remember lefty loosey righty tighty.
    Now that I have muddied the fountain with my two pennies, others who have gapped to .036 may chime in...
    John
    '81 XS1100H - "Enterprise"
      That's not muddy....
      John's giving you the straight poop. Yes, a good-condition OEM ignition system will fire a larger gap, but you'll reduce the longevity of all the parts, if only slightly. 30-year-old bits, maybe more than slightly....
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        There has been some discussion about side gapping plugs before... I havent read any if the technical info on it but it might be an alternative..?
        See here...
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
        • XSive Okie
          • Jun 2010
          • 281
          • Enid, OK
          Thank you, gentlemen. I know it requires more voltage, but didn't think of the "wear and tear" aspect. I have read up on the side gapping method and might try that in the future, but for now, I guess I will stick with .032 for a gap. I only have one spare OEM coil per side and don't want to have to place them in service because I burned up one that is in use.
          Richard
          '02 Honda VTX1800C
