Just need somoene to point in me in the right direction.
  • Crazy Damian
    • May 2012
    • 48
    • Carlisle, Ohio
    checked, double checked, now triple checked.
    10 min ago I would have said I have no electrical issues.
    Until today I had checked all electrical connections, cleaned & checked adavance mech and wires, all was good.
    Tonight I pulled carbs, reset floats, pulled pilot jets to look at them, they are the 2-1-2-1 kind and I also looked at the old ones I took out they are the 2-2-2-2 kind, put it all back together and turned the key and no power.
    The flowchart troubleshooter said -------------------------grab a cold beer, relax and work on it tomorrow.
    Damian
    If it's worth doing, It's worth overdoing!
    Ride it like you stole it, or get out of my way.
    Don't worry if others don't like it, if you like it just smile and ride!
    1979 XS1100SF w/ Flanders "Superbike" Handlebars,
    Upcoming mods include but not limited to, ZRX Carbs, 4-1 exhaust, and a gun fighter single seat, lots of paint, chrome and powder coating.
      • 9980
      Did you get my PM?
        • 5046
        Originally posted by Crazy Damian
        Cleaned and synched carbs, everything idles good, revs good, get it out on the road and WOT 0-110 no problems at all fast as hell.
        Try to cruise at anything inbetween 45 and 75 and I get backfiring and missing on the right side.
        the bad, no mufflers installed thats why I know it's on the right side.
        I checked, and double checked the floats, everything appears to be right.
        Anyone have any ideas.
        Damian
        Don't even try to tune when you don't have muffs. You will be chasing your tail.
          Yep, one thing leads to another leads to another with these bikes some days.
          Did the oil and neutral lights come on (if it is in neutral anyway)? did you bump the stop switch while wrestling with the carbs and such?
          • jwhughes3
            • 2798
            • Home of the Alamo
            Main fuse stock location on left side behind airbox...may have been disturbed during carbs?
            John
            '81 XS1100H - "Enterprise"
              Originally posted by DGXSER
              But wait....According to a recent thread I recall, no one should look at jetting until they are sure they have looke dinto all of their electrical issues.
              well that was in reference to changing to a non stock jet size NOT changing to the correct style jet.
              • Crazy Damian
                • May 2012
                • 48
                • Carlisle, Ohio
                Problems fixed.
                Problems fixed.
                Electrical probelm turned out to be loose connection on the plug from the ignition switch, inside the headlamp bucket.
                checked float hight again today, and adjusted as needed, problem solved, almost still have a little backfiring but much less than before, gonna live with it till I can get mufflers on it.
                Damian
                  Keep an eye on the plugs and make sure you are not lean, do a throttle chop plug check too.
