hey guys, i was on about a year ago and i finnaly got a few pics sent in of the progress, should be done this summer. it's been one of those hit-n-miss projects, but i got going pretty good this winter since i baught a welder. mostly just minor stuff to finish up,fuel line plumbing, wirring, controls,seat, fender support....well hopefully it will be done soon. anybody know if someplace sells drag pipes for these? i have a set from a honda 750 that i can MAKE fit but...
choppin' the XS11
When I worked at a Jeep repair shop, the owner was into the Dwarf cars (little race cars that look like 1930's roadsters with motorcycle engines). Since the engine was turned sideways, the exhaust had to turn 90 degrees from regular bike set-up. Muffler shop down the street did it no problem.
Why not do like on Am. chopper and make your own?
Just my 1½ cents worth. Looking forward to the pictures.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example" -
hey conrad where are your pics
I've been sort of curious on choppers ever since watching occ
and i have considered chopping an xs
i have a parts bike, so it wouldn't be like ruining a real good one
but after looking at the steering head on the xs standard
there is alot of gusseting on and around it
did you modify the original frame or go with a whole different one
and did you start with a standard or a specialhttp://home.securespeed.us/~xswilly/
79F Parts
80G Parts
75 DT 400B enduroComment
hi guys. don't know about the pics, i sent them but maybe did it wrong? as far as the frame goes, i left the neck area alone, going more for the "bobber" look then the typical long fork chopper. what i did was cut off the whole rear section, from the engine cradle back and bult my own rigid rear section, with about an 8" stretch. i believe it was a special, but honestly i am not sure of the difference.Comment
CUT OFF REAR END SECTION
So Conrad, you cut off the rear end, so does this mean your going to use a chain drive rear end. If so,I sure whould like to see some pictures, because I'am trying to find some info on switching to chain myself, so I can switch to a bigger tire and a custom rear fender.Originally posted by conrad
hi guys. don't know about the pics, i sent them but maybe did it wrong? as far as the frame goes, i left the neck area alone, going more for the "bobber" look then the typical long fork chopper. what i did was cut off the whole rear section, from the engine cradle back and bult my own rigid rear section, with about an 8" stretch. i believe it was a special, but honestly i am not sure of the difference.Chris 79 XS11F With mods....!!!!!! 2005 FXST Harley SoftailComment
hey conrad
the way to put pics up
is to upload them to your own storage on your isp
then send us a link to them
when you reply to this post, up above where you are typing there is a button, marked IMG
push that then type in your storage for your home page on your isp
something like www.myisp.com/conrad/bike.jpg
kinda the long way around
but it would take up alot of space on this site if everybody uploaded all there pictures
good luckhttp://home.securespeed.us/~xswilly/
79F Parts
80G Parts
ok, i think it worked. sombody let me know?
sorry bikeboy, cant help you on the chain drive, mine is staying shaft and the driveshaft will be getting stretched. however, by eliminating the swing arm and leaving the driveshaft exposed, there is a little bit more clearance for a wider tire, maybe. as far as a custome fender, odds are good you would need to notch it to clear a chain, you can just notch it to clear the shaft. that's what i'm doing, anyhowComment
Gday you lot!
I loved riding in the snow when i lived in the UK, The bike was a 1980 CB650z chopped to the teeth, low rear end, standard front end, **** me it went well, have a look, I still own it and now we all live in perth australia http://www.members.tripod.com/coskys0/id18.htm
this will save you a lot of space, build your own web site
see ya from xsentric (Cosky waz ere)Comment
