81 brake help
  • Nick7777
    • May 2012
    • 121
    • Michigan, U.S.A.
    81 brake help
    so the front end on my MNS is apparently the one off of the 81 venturer i recently sold, anyone have pictures of what the front caliper mounts look like, i am going to have to machine them after hours at work and it would be most helpful if i had some measurements between hole centers.
    80 MNS; 81 Venturer
    Apparently? Does that mean you don't know for sure or what? Does it have the leading front forks or is the axle center under the forks?
      I guess the question is, what kind of calipers are you mounting? If you've got 'standard' forks and are trying to install OEM brakes, just buy a set of used mounts. It's a fairly complicated casting, I wouldn't want to build one...
      • Nick7777
        • May 2012
        • 121
        • Michigan, U.S.A.
        PO said he had swapped em with the ones off the parts bike had, unfortunately i sold the parts bike already
        80 MNS; 81 Venturer
          • 2104
          You may...
          ...want to read this thread:
          • Nick7777
            • May 2012
            • 121
            • Michigan, U.S.A.
            Originally posted by Schming
            good news is it is the whole assembly, triple trees and all. one less cobweb to sort through, nonetheless a good read and thank you for the advice.
            80 MNS; 81 Venturer
