Stalled need help asap
    Agree with the others. You were running on the battery since it wasn't charging for some reason. Since it's obviously night now, you'll need a light, but like John said, if you hook up some jumper cables to a car and let it charge for a bit, 15 miles on just the battery shouldn't be a problem, just try to keep things minimum. Don't use turn signals and keep the headlight on low beam. If the battery gets below @ 10.8 volts, not even the kick starter will help you.
    • mmaddix
      • Jul 2011
      • 232
      • Beaufort, SC
      Thanks anyways man but I finally got ahold of some people and I'm about to test the chatting system
      USMC 2005 - Present
      79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
      78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!
      • mmaddix
        • Jul 2011
        • 232
        • Beaufort, SC
        Thanks for all the help. Like I said I finally made it home. I decided I'm going to work on it tomorrow. I pulled the battery out and charging it tonight so I can do the charging system test with my multimeter tomorrow.
        USMC 2005 - Present
        • GARTHXS
          • Nov 2007
          • 1631
          • Seattle
          Yeah those sealed battery are crap they usually give up in a year
          91 kwaka kz1000p
          Stock
          ( Insert clever quote here )
            • 6765
            I bought a sealed battery nearly 3 yrs ago for the XJ and its still fine...i hate batteries you have to add fluids to...they can leak spilling battery acid that can acid stain your chrome exhaust...ask me how i know...so i went to a Gel battery and never looked back...
            2005 Honda SilverWing 600
            2018 Honda PC-Xpress 150
            • soccer4m
              • 694
              help
              Hi, I can help Scoot and you load it up this eve,afternoon, I also have a ramp and trailer, plus it would be good meeting a few more xs owners. Let me know, otherwise its off to the beach to surf. I am BETTING its your battery. I had same problem with a sealed battery, it died within a year. Some of the better ones last a long time, the cheaper Chinese ones die quick.........at least we can check it out for you, I can pull out one of mine and fire up your bike and see,,,,,,,, Mike in Valley Center
              mike
              1982 xj1100 maxim
              1981 venture bagger
              1999 Kawi Nomad 1500 greenie
              1959 wife
              • soccer4m
                • 694
                late
                Uh,,,,I posted previous post after reading first page of forum, glad you made it home. Definately charge the battery up,,,,NOW TAKE IT TO AN AUTO STORE TO TEST IT,,,any PEP BOYS, AUTOZONE etc, can hook it up to a machine and test it for you and get a true reading of the battery. AND, now if battery tests good, pop it in the bike, get a multimeter and test voltage on a running bike across the battery and a non running bike across the terminals,,,,,it should read over 12v. running and less non running if your battery is good and charging is good. Keep us informed........Mike in S.Diego
                mike
                1982 xj1100 maxim
                1981 venture bagger
                1959 wife
                • mmaddix
                  • Jul 2011
                  • 232
                  • Beaufort, SC
                  I got the battery checked at AutoZone and they said the battery was good. When I read the battery before I started the bike it read 12.6 v and after I started it the battery was reading 12.3v and was slowly going down. Definitely the charging system.
                  USMC 2005 - Present
                  • mmaddix
                    • Jul 2011
                    • 232
                    • Beaufort, SC
                    Just read through the stator and it is definitely bad. I'm about to check the one on my spare engine to see if its good. If its not good does anyone know anywhere in San Diego that will have them in stock and about how much one cost?
                    Thanks again everyone for the quick replies yesterday.
                    USMC 2005 - Present
                    • mmaddix
                      • Jul 2011
                      • 232
                      • Beaufort, SC
                      I put the stator in from my spare engine because it read good. The battery read 12.51 before I started the bike and 13.3 after I started it.
                      You guys are awesome.
                      USMC 2005 - Present
                      • soccer4m
                        • 694
                        congrats
                        Big congrats, glad it was narrowed down to the stator, and hoping you get a full charge and the xs runs like it should. Now to go riding ehhh? We have the local guys in San DIego, so don't be a stranger. Garth and me love to go up your way to the Casinos and eat for a short xs run....see ya, Mike in Valley Center
                        mike
                        1982 xj1100 maxim
                        1981 venture bagger
                        1959 wife
                        • mmaddix
                          • Jul 2011
                          • 232
                          • Beaufort, SC
                          Yea something like that sounds good. Send me a message sometime. Or get my number from Garth. He helped me out and took a look at my rotors back in Feb. If he doesn't have it just send me a pm and I can get it to you.
                          USMC 2005 - Present
