I would have a buddy pace you with a car, use hand singles for differnt speeds. like 25, 35, 45, 55, 60,65, 70. Also if you have a smart phone you can use a speedo app. I have Speedview on my razr. it is free and was dead on when I tested it agaist my car's speedo. Then you will know if and how much your speedo is off.
Is my speedometer wrong?
Ok, I was way off, sorry. That was in 4th gear I was recalling. Been so long since I rode the beast due to wheel rubbing and a miss that I forgot.
78 XS750Comment
I've got an android phone and just downloaded Speedview. Great idea, I never thought of doing that. I will just have to figure out a way to secure the phone to the tank (or ride with it in my hand, without wrecking).1979 Special with 1980 motor and 1979 carbsComment
I didn't ever think that a standard and special cable would be different. My bike has the stock,round 160mph speedometer, and I assume it's the original one but I've only had the bike for a year or so. Also, I don't know if it's ever been opened or tampered with before.
What would also be convenient is to find one of those unmanned police radar units they usually setup near construction zones that show your speed to warn you to slow down. But I live in a rural area and we almost never see those around here.1979 Special with 1980 motor and 1979 carbsComment
Hi Jeremy,
my experience with XS series speedos is that the odometer readings stay right but the speed reading tends to get slow as they age so yes, your speedo may be wrong.
If yours has been opened by a PO there will be pry marks on the back of the bezel, those speedos are a swine to open & re-seal.
Easiest way to check the speedo's accuracy is to use a GPS, most of those have an MPH readout and will do the odometer check too.Last edited by fredintoon; 07-16-2012, 08:24 AM.Fred Hill, S'toon
"The Flying Pumpkin"Comment
off by 5mph
I checked my speedo with my GPS and it is telling me it is off (high) by 5mph. Ant suggestions on how to correct? It has never been apart.
Just ME and my 82 XJ 1100. Mac 4>1-2 1/2" open baffle shotgun, no octy, K&N pod filters, LED tail/brake light & directionals, 750 FD mod, Ear Cannon air horn, modified bars and dash. "Motorcyclists are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what machine he rides as long as he belongs to the clan." Walter Davidson, Dec. 1920 edition of Harley-Davidson Enthusiast Magazine http://s851.photobucket.com/albums/ab78/justme1100/Comment
Suggestion: Realize it is high by 5 MPH and learn to adjust it in your head.
Not much else you can really do IMO.
78 XS750Comment
Larger front tire, 110/90/19 Shinko will correct the speedometer ratio on the 79 Special. It's a tight fit to the fender but it works fine and looks awesome. Not sure if it will fit an XJ.Last edited by bikerphil; 07-23-2012, 03:39 PM.2H7 (79) owned since '89
☮Comment
be careful with using those unmanned police speed signs sometimes they hook up camera calibrated units to them and then you got a ticket.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
http://s1184.photobucket.com/albums/z329/viperron1/Comment
Hey Jeremy,
As stated, you don't want to go into the speedo case, a real PITA! Do a search, I've read a few posts where folks have spritzed oil or such into the speedo in specific locations to help lubricate the works without getting it onto the glass and such. Sounds like the grease may have gotten aged and stiff/sticky and so the needle can't swing up as far as it's supposed to. One thing I've also learned is that when in 3rd gear, the tach/rpm is almost exactly the same as the speed!
T.C.T. C. Gresham
I had a situation with my odometer where every seond or third tiem it woudl switch tens it would switch the hundreds also. I was getting three to five hundred miles on a tankful!!
I di dopen up the speedo case, it is a PITA. Cleaned it all out, sprayed it out with carb cleaner in there, then sprayed it with WD40 to lubricate it all nicely. Then put it all back together. Should have taken the time to repaint the ring before reinstalling though.
It works perfectly now, but I am not certain that would be as effective on the speedo part.
78 XS750Comment
Yeah, but then the odometer is off. If it's that important to have the speedometer right on I'd spend the money at a calibration shop and have them open and calibrate it, they have the technology to make it right on, but it will cost.Cy
Cy, my odometer is off by 1/10 a mile every 2 miles, no biggie. I would personally rather have the speed correct.2H7 (79) owned since '89
☮Comment
My speedo is 2 to at least 5 mph high. I only check up to 80 mph though, and it gets progressively farther off the faster I go.Nathan
Theodore RooseveltComment
