Argh! Choke springs...
  • BobBaldy
    • Apr 2012
    • 43
    • Evansville IN
    When I started cleaning my carbs I saved the little ball bearings (still have them) but I couldn't get the springs out of the choke mechinism. I figured they were frozen in place. I figured wrong. Somewhere on the way to the weld shop to get the carb post TIG welded back together ($10, perfect job) the springs fell out.
    So. Does anyone either have a pair for sale or know where I can get them?
    80 G, Spaghetti pipes, K&N in stock airbox, Galfer S/S lines.
    It has been my experience that folks who have no vices have very few virtues. -Abraham Lincoln
    http://80xselevenrebuild.blogspot.com/
  • petejw
    • 2269
    • sydney australia
    ive never tried it but have heard a spring
    from a pen might work. jat
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • BobBaldy
      • Apr 2012
      • 43
      • Evansville IN
      I'll try that when I get home, but I think the originals were a smaller diameter and tighter wind.
        Originally posted by BobBaldy
        ...but I think the originals were a smaller diameter and tighter wind.
        They are....
        Sending you a PM...
        • Aches n Pains
          • 349
          • Reston, Va.
          Crazy Steve helped me out with the same problem. Also put me into some of the ball bearings at the same time. Great guy and a huge help.
          1995 KZ100P
          Pods, jets, pipes, cam adjuster, oil cooler
          1977 Ironhead - custom build
          Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
          Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
            Those springs are MUCH stronger than a pen spring. I have sused a pen spring to substitute for the brake light switch, but they woudl not hold the choke in place.
