Brake warning light XJ11
  • KA1J
    • 664
    • Groton, CT
    I just attended to one warning light issue http://www.xs11.com/forum/showthread...826#post381826 and there is yet another that has me confused with how to proceed.
    The brake light warning light comes on frequently. It is often on soon after I start the bike and turns off for long periods but when I turn off the bike for awhile, the light comes back on. Whatever I do to the front brake seems to have no bearing, it's seemingly the rear brake that causes the fault but by habit I use both brakes at the same time.
    I checked the fluid level and it was fine. I did add more fluid till the reservoir was 100% full and still the warning light comes on every so often. I never had this issue till several weeks ago. There seems to be no issue with the brake working properly, both front and rear calipers were rebuilt & there's new brakes all around. I replaced all the original hose lines with SS lines last year.
    Idears what I might do to resolve this?
    Thanks
    Those are nothing more than little floats in the reservoirs, they may be dirty. I think these are reed switches (magnetic operation), so they can be affected by crud.
    • KA1J
      • 664
      • Groton, CT
      I've not looked inside the rear MC for the floats, only seen the one in the front MC reservoir. How might I best go about cleaning these switch contacts? They are immersed in new fluid but they had been sitting for a long time before I got the bike & restored it.
      Thanks!
        I haven't actually had mine apart (I converted to 'normal' brakes so I'm not using the XJ masters), but assuming they're similar to most that I've ran into it's just a small float with a magnet in it; it's a common design as it doesn't need to be 'sealed'. They collect 'stuff' over time and don't float as well. Best bet is clean/flush the reservoir out, you may have to re-bleed the brakes.
