I am getting a really annoying vibration through the rear engine mount bolt. I don't think that it is actually coming from the engine though. Before I put the floorboards on my right peg vibrated pretty good at highway speeds and the left peg vibrated less but still an annoying amount, BUT if I put just a slight amount of pressure on the rear brake pedal (not enough to actually apply the brakes though) the vibration would go away. Now with the floorboards the vibration is worse and I cannot make the vibration go away with the brake pedal like before.
First off, I have never felt that my rear brake spring was correct so if someone had a pic of how that spring is supposed to be installed that would be great!
Second, if anyone has any ideas on other things to look at that would be splended.
Third, Not a huge fan of how I need to have the brake pedal and the downshifting side of the heel toe shifter so if anyone had any ideas on how to modify those things that would be great. And if anyone had a bent up brake pedal and shifter that would be great, I really only want to splined portion so that I can play around and try and make some controls that might fit better.
