Brake Switch
  • Brake Switch
    The POS Mikes XS rear brake switch that I replaced my old switch with broke in half midway up the adjuster barrel. I just got the bike running after all my other electrical issues and front fork problems and suddenly no brake light. I pulled the switch off my F since it won't be going anywhere soon and got it hooked up. The first thing I notice is now I have a brake light. The second is the spring attached to the brake pedal is a gazillion degrees and sparks are coming off it where it touches the frame. I checked the switch with a meter and one side of the switch pigtails is grounded to the spring. Anybody know whether the pressure activated switches will work on the rear brake cylinder?
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    Originally posted by Toolmaker Tim View Post
    ...Anybody know whether the pressure activated switches will work on the rear brake cylinder?
    No problem... See if you can find one of the switch/banjo bolt combos...
      I LOVE those. I use them on everything. Its a banjo bolt with a hydraulic pressure switch built right in. inexpensive, easy to install and VASTLy more reliable than any mechanical switch.
        Hydraulic Pressure Switch
        Ok, Just ordered one, we will see how it goes. This has been a frustrating chain of events.
        1979XS1100SF
        Jardine 4in1
        Dunlop Elite 3's
        142.5 main jets
        45 pilot jets
        750/850 FD mod.
        XV 920 Needle Mod.
