oil light
  • KA1J
    • 664
    • Groton, CT
    oil light
    Recently the oil indicator has been coming on. It lasts for roughly 20 seconds and then goes out. It happens under acceleration but continues when I'm going at a steady speed. When the bike is on the center stand the level of oil is 2/3 up the window. I changed oil 3K ago and installed a K&N filter at the time. I don't recall the amount of oil but it was from the service manual with a filter change.
    Any suggestions?
  • tcoop
    • Nov 2009
    • 793
    • South Weber, UT
    Your sensor may need to be pulled and cleaned.
    Ty
    78 XS1100E - Now in Minnesota
    80 XS1100LG - The Punisher
    82 XJ1100 - Daughter's Bike
    • KA1J
      • 664
      • Groton, CT
      Thanks.
      I just pulled it but it's not something with moving parts on the outside. What is safe to use to squirt in it or dip it in? I assume I then should shake it to move the internal float?
      • tcoop
        • Nov 2009
        • 793
        • South Weber, UT
        I would use Marves Mystery Oil or some penitrating oil. You would need something that will break up any build up in there.
        Ty
        • KA1J
          • 664
          • Groton, CT
          I decided to give a try with seafoam in a narrow cup that fit the sensor. I soaked it in there for 20 minutes or so & drined it, shook the sensor up & down to free it, re-immersed it again & rinse, wash repeated that several times and re-inserted it. Finally it was seemingly free to move and I re-installed it.
          I could only run the bike for maybe 8 miles before leaving it for the weekend but during that 8 miles, the sensor light didn't come back on. So perhaps a'la Borat; Great Success!
          If it comes back on, I'll revive this post.
          I have issues with the brake light but I'll put that in a separate post.
          Thanks!
            Hi Five!!!!
