ballast resister missing?
  • mikubuilder
    • Jul 2011
    • 548
    • Westland, Mich.
    depending on how long the bike has been sitting, you might want to spend some time cleaning all connectors, and probably update your fuse box (TC sells one for about 10 USD)...BTW worked great for me, made a huge difference in voltage to TCI....
    Nick
    1982 Virago 750 (it's alive!)
    • Wrench Twister
      • Jul 2012
      • 21
      • Peterborough, Ontario, Canada
      Yeah thanks for the reply, I did all that couple weeks ago. that's how i found out how badly the harness had been sliced and diced. lol. Lots of twisted together wires wrapped in tape etc. When i got the bike it had no fuse panel at all just the fuse holder ends taped together. I'm really amazed it didn't burn before now. I removed the carbs and have them soaking in cleaner, Ill rinse and blow dry them after work, they were full of rust as is the tank. Good times!
      • Wrench Twister
        • Jul 2012
        • 21
        The '81 bikes didn't have the ballast resistor (first year it was deleted),
        Just another question, if the '81 model didn't use the ballast resistor should i be replacing the junk coils with 3 ohm type. At the moment it obviously has 1.5 ohm coils on it. The PO could have put the wrong ones on for all i know. Which type will give me a better spark. Thanks. Vic
          Yes, you need the 3 ohm. Running the 1.5 ohm coils will burn up your TCI...
          • Wrench Twister
            • Jul 2012
            • 21
            Looks like these have been with the bike for a long time. I hope the TCI is ok. Are these TCI's hard to find or are there aftermarket replacements to be had that are plug and play. Will the tests results be the same from the secondaries on both types? Thanks for the info. Vic
