switch controls
  • TomRodgers
    • Jun 2008
    • 492
    • La Porte Indiana
    switch controls
    Hey guys.... quick question....will the handlebar controls from MikesXS work on our beloved 1100's?? i have a parts bike that im putting together with a friend of mine....and the switches are ZAPPED!!!!
    '81H (my first XS ) "Grey Ghost"
    4:1 Jardine w/ headerwrap
    Windjammer(wiring issues)
    New paint/brakes to come!!
    '80G FrankenBike (parts bike)
    '80G to fix "BlackSunshine"
    Stock Pilots/125 mains
    Pod filters; 4:1 Kerker??
    SS Brake lines w/ new M/C's
    LED Brake Lite
    Needs paint....
    • 8052
    Yes. You have to repin the connectors, as the wiring won't match your application.
    • TomRodgers
      • Jun 2008
      • 492
      • La Porte Indiana
      okay..... not sure what ya mean..... i assume the 650 connector has different # of pins?? could i cut/splice wires to match????
      LED Brake Lite
      Needs paint....
        And the mikes XS controls do not have the hazard switch. You could gowecer use the old housing and hazard switch and the new internal from the mikesxs ones.
        • TomRodgers
          • Jun 2008
          • 492
          • La Porte Indiana
          my switches dont have a hazard.....maybe bastard switches from a PO???
          LED Brake Lite
          Needs paint....
            • 8052
            Tom,
            Don't cut any wires. I don't know if the 650 has the same shape connector or not. In any case, the wires will likely be in the wrong positions in the connector for your bike.
            When the pins are installed in the connector, there's a small tab that pops up to lock it in place. You should be able to find something to push it down and remove the pin and the wire. Using an ohm meter, you should be able to figure out which wire goes to what switch. Reinstall the wires/pins using the wiring diagram for your bike.
              Don't cut and splice here! Just opening yourself up to corrosion later on. The pins can be remived from the little plastic connector, so take the connector off of the new switch housing and then one by one take the wires out of the old plastic connector and put the new wires from the new housing in so that all the wire functions match up
              No hazards, no problems with that then. I think '80 is when they started putting the hazards in there. Prior years did not have hazards.
                • 8052
                80 & 81 Specials have the HAZARD switch. It may be the same for the standards, but I'm not qualified to answer that. For sure, not all XS11s have HAZARD flashers.
                • TomRodgers
                  • Jun 2008
                  • 492
                  • La Porte Indiana
                  all 3 bikes are standards, and do not have the hazard switch.... i guess i will pop for the 2 units and see what happens!!! LOL
                  LED Brake Lite
                  Needs paint....
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    80 and 81 standards in stock shape have the hazard switch as well, it's common to the 80 and later bikes, the control pods are the same for special and standard at least as far as the controls go.
                    • Poprock
                      • Apr 2005
                      • 594
                      • Oregon Coast
                      Radio Shack has a pin remover tool. Works pretty good. Slips down over the pin, depresses the holding tip, then the plunger pushes it out the back. Also removes tubes the same way.
