Burning oil After Rebuild
  • Rettic
    • May 2009
    • 142
    • Charlotte, NC
    I just rebuilt my engine about 2 months ago and I am burning oil on my #3 cylinder.
    Parts I replaced:
    Rings (got the cylinders honed)
    Valve Seals
    Crank Bearings
    I just finished replacing the seals on #3 again thinking that I fubared one of them up without knowing it. I took it for a short spin and I am still burning oil, the plug is wet with oil. The Compression on #3 is 150. Any thoughts on where to look next? I am fairly confident the oil rings were put on correctly. The bike runs strong with the oil any how. I am at a loss and hope I didn't mess the engine up with the rebuild.
    Thanks!
    1979 XS 1100SF Serenity
    1981 XJ650 Midnight - Black Betty
    Road Dog 4 Life
    How many miles since the rebuild?
    • Rettic
      • May 2009
      • 142
      • Charlotte, NC
      515. It is alot of oil that is being burned. When I replace the seals I had to re-clean the combustion chamber, had alot of build up on the exhaust valve.
      Road Dog 4 Life
      • James England
        • 3039
        • North of England
        And you replaced the valve stem seal after you discovered it was burning oil, right?
        • Rettic
          • May 2009
          • 142
          • Charlotte, NC
          Yes, replaced both of them, Intake and exhaust. All others are running normal and clean.
          Road Dog 4 Life
          • James England
            • 3039
            • North of England
            There is obviously oil entering the cylinder. It can only come through the valve stem seals (unlikely), or round the piston rings.
            Could the head gasket have anything to do with it, someone?
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              If the head gasket was leaking then he'd see it in the compression readings.
              What about the intake valve seal? (Sucking oil in. the exhaust would tend to blow out wouldn't it?)
              If the compression numbers are good, then the cylinder is 'sealing' up okay. (good valve seats and good rings)
              The only other way in is like james said, the valve seals.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
              • Rettic
                • May 2009
                • 142
                • Charlotte, NC
                Seems odd that new seals would not make a difference. Just finished putting replacements in again. What about valve guides? Could it be leaking in from the guides? Are there any tests I can do to find out where the leak is coming from?
                Road Dog 4 Life
                  If your guides are bad enough, new seals won't last long. I'd look there to start...
                    • 8928
                    That much oil being burned, you might have broke the brittle oil control ring on reassembly. Or the two gaps in the ring may be in line with each other instead of 180º apart. JAT
                    • petejw
                      • 2269
                      • sydney australia
                      a quick test to see if its rings or valve seals,
                      start the engine and let it warm up, run it at a
                      fast idle around 3/4000rpm hold that for a cpl of minutes
                      and see if it starts blowing smoke, if so theres problems
                      with the rings,
                      now just chop the throttle, if it smokes then, its sucking
                      oil down from the valve seals or worn guides.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      1981 xs1100 RH (aus) (5N5)
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • WMarshy
                        • Apr 2009
                        • 2402
                        • Mexico NY
                        Sounds like a good point to perform a leak-down test on you engine (cylinder). These seem like a decent tutorial on how to build and perform the test...
                        Building a leak-down tester:
                        Performing a leak-down test:
                        '79 XS11 F
                        Stock except K&N
                        '79 XS11 SF
                        Stock, no title.
                        '84 Chevy K-10 "Big Blue"
                        • Rettic
                          • May 2009
                          • 142
                          • Charlotte, NC
                          3-4k rpm shows its the rings I guess, smokes good while holding the RPMs up and then once I let go it still smokes a little then goes down to almost none at idle. The plug is fouling and you can see oil deposits along the edges. Should I get new rings for that piston? All the rings on all 4 are new. Would a to large of a gap be a cause for this as well?
                          Road Dog 4 Life
                            Too large a gap and/or gaps not spaced propperly could be the cause. Might have to POP the head off and check.
                            • WMarshy
                              • Apr 2009
                              • 2402
                              • Mexico NY
                              See Phil's response above about having the gaps lined up... I wouldnt buy new rings until its properly diagnosed with the leak-down but each to their own...
                              '79 XS11 F
                              Stock except K&N
                              '79 XS11 SF
                              Stock, no title.
