Poor Running - HELP
    • 8796
    Just remember, if the bike doesn't get ridden too much, always a good idea to add fuel stabilizer of some sort. These carbs as you know have very small passages which easily clog with todays crappy fuel, glad you got her running well, good luck!
    07 Triumph Tiger 1050
    • Poprock
      • Apr 2005
      • 594
      • Oregon Coast
      Good candidate for some Sea Foam.
      • MPittma100
        • Aug 2011
        • 2359
        Poor Running - Fixed
        The fuel additives are a good idea. I added some after the fact. So it did not do any good. An additive that is being talked a lot about recently is K100. All of the motorcycle/4 wheeler dealers are carrying this now. Supposed to be better than Sta-bil. I bought some from K100 direct (online). They have additves for gas, diesel, etc. Supposed to combat the bad things that are in gas nowadays.
        MP
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
        • MPittma100
          • Aug 2011
          • 2359
          Hi Guys,
          Concerning the ethanol in gasoline fuel issue, K100 Fuel Treatment addresses what they call "Phase Separation" on their website. Looks like this may be a possible cause of some of our pilot jet clogging. I am trying some now and will report the results as they come about.
          Most all motorcycle/4 wheeler dealers carry K100. you can also purchase it directly form the website. They make a treatment for diesel fuel as well.
          http://www.k100fueltreatment.com/PhaseSeparation.html.
          MP
          K&N Air Filter
          ACCT
          EBC Front Rotors
          Mike
          • WSL91
            • Feb 2012
            • 427
            • Quad Cities, IL
            Hum, still wondering how phase separation can occur on a bike that's ridden frequently. The bikes bounce down the road and when we fuel up there's a strong current in the tank mixing it up. I'm simply not a believer in that application.
            In a large fixed storage tank where fuel sets for long periods, I can buy into it. I do use Stabil for extended (winter) storage in my motorcycles, lawnmowers, and tractors when the equipment does not get used.
            I have 3 tractors in storage that I start every 6 weeks. In October I will drain the tanks and fuel back up with fresh unleaded gasohol with Stabil. The tractors will not get filled again until next fall. The last 2 years I've drained the tanks and never seen any evidence of separation. In fact the fuel that comes out goes right into my Silverado's tank for "disposal". My main goal is to keep condensate out of the tractors tanks and hopefully prevent rust. One could make the case that I'm seeing the results of the Stabil and the tractors really just set.
            In the tractor world the pilot/idle jets are the smallest in the carb and always the first to plug. I've never seen one plugged with water but I've seen a lot of real fine foreign material in them
            1970? Honda Z50... gone
            1974? Yamaha 100 Enduro... gone
            1974 Honda CB200... gone
            1981 Yamaha Virago 750... gone
            1993 Honda Shadow 1100... gone
            2008 Honda VTX 1800F
            1982 Yamaha XJ1100J w/850 final, Raptor ACCT
            1979 Yamaha XS1100SF "Chewey" Raptor ACCT
            http://www.johnsoldiron.com
