xj brakes wont stop stopping
  • XJfan1
    • Feb 2012
    • 180
    • Huntington,Indiana
    My front brake on the ape is dragging so i pulled the caliper off and i have it here at work on the bench. I can't for the life of me get the piston out. I shot some blaster in it and tried to wiggle it with a pair of channel locks it just barely moves. i put 125 psi of air to it and it still wont wiggle out with channel locks. I'm thinking about screwing a grease gun fitting into the hole and seeing if the pressure from pumping grease into it will work it loose. please help!!!
    1982 xj 1100
    "The Ape"
    http://youtu.be/AiQ8CqclHr4
    Put a bolt in the hose connection hole, then put the grease gun on the bleed screw (cracked open of course). Give'er the grease and the piston will come right out....
    You'll have a mess to clean out, but this works every time. You probably have corrosion behind the piston seals.
    • newc4
      • 606
      • Vienna VA
      Just hook it up to your master cylinder while clear of the rotor and pump it out that way. Do it over a container so you don't get fluid all over.
      Darrell
      78E
      80G project
      06FJR
      • XJfan1
        • Feb 2012
        • 180
        i put the bleeder back in and the grease gun hose screwed right into the hole worked perfect.
        1982 xj 1100
        "The Ape"
        • James England
          • 3039
          • North of England
          Ten points to Steve in the James England 'Win a free rear left side wheel bearing by being clever' competition! Only 90 points more to get, Steve!
          • petejw
            • 2269
            • sydney australia
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • jwhughes3
              • 2798
              • Home of the Alamo
              Font is too small
              Pete I cannot read your response. The font is too small and just looks like dots to me.
              What does it say?
              John
              '81 XS1100H - "Enterprise"
              • petejw
                • 2269
                • sydney australia
                hey john, had replied before realizing
                he got the piston out, i couldnt delete the post
                so put ......... instead.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • LoHo
                  • Sep 2002
                  • 1342
                  • Fresno, CA
                  __________________
                  pete
                  Yeah, I have the same problem...by the time I get through typing, the guy has usually sold the bike.
