Just don't throw the old one away until you thoroughly check it over. No sense throwing away a good backup even if you happen to be the Bearing Baron!
Rear wheel bearing LEFT side
Theodore Roosevelt -
Yes, agreed. Although I must say, on the several I've stripped and the XS's I've had over the years, once a bearing is thoroughly cleaned and all that candle-wax looking grease and whatnot removed, it's been rare that the bearing doesn't feel a bit on the loose side and, more usually, there have been gritty spots and a kind of crunchy feeling when the inner race is spun.
I think pressure washers are partly responsible. That and plain old neglect. Pressure washers can blast water just about anywhere, even past bearing seals. My XJR has a kind of open alternator on it, like a car, with the inner windings plainly visible through slots. It freaked me out a bit when I first got the bike, actually, I dread to think what a pressure washer would do inside it! Also, with the XS, the rear bearings are easily forgotten...a bit like the shaft bearing that never gets enough grease, if any, by the 'Zerk' gadget...
On the last couple of bikes I did up, I just replaced all the wheel bearings anyway. My theory is that one can end up always doing something if they aren't all renewed at the same time. Ok, I maybe take it a bit far but once they're done, they're done. And I am, as you say, a Bearing Baron!
XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Yeah, the rest of the bearings are cheap and plentiful. Might as well change the rest.Nathan
Theodore RooseveltComment
It feels good too, knowing the bearings are all done...wheels, steering head, swinging arm etc. I do think that, for a resto project, it's better to do the lot. It can be relatively easy to make a bike look right but not much fun to be forever messing about with one thing after another, especially once the bike has all been painted, frame done etc. That's for a restoration project though, as opposed to a daily use, not so pristine bike that's more of a workhorse. Kind of different things and equally as good in their own ways.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Well then, don't forget the swing arm bearings while you are at it.Nathan
Last edited by James England; 04-01-2014, 02:23 AM.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Bearing update
Just a little update on the bearings. I now have a total of 12 available. It was 13 but I used one in my new project!XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
