turn signal problem
  • mmaddix
    • Jul 2011
    • 232
    • Beaufort, SC
    turn signal problem
    Alright so my front turn signals on my project bike are on all the time. They only turn off when it is supposed to turn on and nine of my turn signals flash. I know I probably need a flasher relay but would that cause my front ones to stay on besides when they are supposed to flash.
    I thought about it and are the front ones usually on at all times and only flash when you select the turn signal. Because that would explain everything.
    USMC 2005 - Present
    79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
    78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!
    • 8082
    Yes, the front signals double as running lights.
      Hey Maddix,
      You've got wires crossed in the front. The standards have both running lights...the blue wires, and turn signal lights, the green and brown wires. You've probably got the blue and others mixed up and cross connected. You'll need to pull your headlight out and check the wiring and connections.
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        Or you could have the wrong bulbs in there.
        Yes, Those turn signals double as running lights and thus need 2 filaments.
        So, the bulb will have two contact points on the bottom. If you use one that only has one contact point then you're essentialy crossing the wires right there in the bulb socket.
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
        • GLoweVA
          • Jun 2011
          • 1957
          I need to add the fact that if you've got the stock flasher (3 prong) then you need to make sure that you get the right wattage bulb too. (27W for the signal is what is needed.) Anything less than that and they won't flash, just stay on.
          Look at the packaging and read the fine print and it'll list the rating of the bulb. I found mine at AutoZone.
          Edit: 1157 is the front 1156 is for the rear
          The 1157 is the 2 filament type and the 1156 is a single.
          The Green Monster
          Got him in '04.
          Scarlet
          Got her in '11
          Hugo
          Cold weather ride
          • mmaddix
            • Jul 2011
            • 232
            • Beaufort, SC
            I got a new flasher and everything flashes but I do need to put the right bulbs in the front.
            One thing that doesn't make sense to me is that if the bulb is two filament doesn't it need two power wires(one for each filament) and 1 ground?
            USMC 2005 - Present
            • GLoweVA
              • Jun 2011
              • 1957
              The ground is the signal housing itself thru the forks and frame.
              If you're wired up right, then you've got two 'hot' leads going into the signal.
              I believe it's a blue for the running light and a dark green for the right signal/flash. (and chocolate for the left)
              An easy check, is to look into the bulb socket and see if there's 2 contact points that would mate up with the 2 filament bulb.
              The Green Monster
              Got him in '04.
              Scarlet
              Got her in '11
              Hugo
              Cold weather ride
              • mmaddix
                • Jul 2011
                • 232
                • Beaufort, SC
                I definitely just had a stupid moment. I want thinking about it getting a ground from its mount because I don't have them mounted I just have them dangling there. If would of took a quick look at the schematic I would of answered my own question. I touched them to a good ground on the frame and they work a advertised. I guess all I needed was a new flasher. Thanks for the input.
                USMC 2005 - Present
                • GLoweVA
                  • Jun 2011
                  • 1957
                  Glad we could help.
                  Curious, did you get a stock flasher, or an aftermarket 2 prong one?
                  The Green Monster
                  Got him in '04.
                  Scarlet
                  Got her in '11
                  Hugo
                  Cold weather ride
                  • mmaddix
                    • Jul 2011
                    • 232
                    • Beaufort, SC
                    It is the stock 3 prong but its just shorter than the original.
                    USMC 2005 - Present
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      Cool, then your auto cancel feature should work too.
                      One thing I have noticed with the stock flasher is if your voltage is low, it tends to not flash well or not at all. I like to think of it as a sort of voltage sensor telling me that my alternator/battery/charging system is working ok.
                      The Green Monster
                      Got him in '04.
                      Scarlet
                      Got her in '11
                      Hugo
                      Cold weather ride
                      • mmaddix
                        • Jul 2011
                        • 232
                        • Beaufort, SC
                        That is good to know. Thanks man.
                        USMC 2005 - Present
                          Is it an actual OEM unit or just some 3 prong you picked up at a auto parts store?
                          • mmaddix
                            • Jul 2011
                            • 232
                            • Beaufort, SC
                            All I know is it has 3 prongs and I got it from a motorcycle salvage yard and they said it was new.
                            USMC 2005 - Present
                              I would be interested to know what it actually came from and if the self cancelers actually work.
