K&L Caliper Rebuild Kits
  • Prothec
    • Jul 2007
    • 587
    • Fort Myers, FL
    I'm looking for caliper and master cylinder rebuild kits for my '78.
    As I've been looking, I could get the combined set of 5 kits off georgefix for ~$111 on e-bay and be done with it, but I found I had a rebuild kit left over from my XJ that says it fits the '78 front caliper. I'm confused about the part numbers and fitment.
    '78 Fitment:
    K&L 32-1250 = Says fits front and rear calipers
    K&L 32-1605 = Says fits front calipers (~$6 cheaper than the 32-1250)
    I will probably end up just buying the kit from georgefix, but anyone know what is different about the kit? Are you paying for an additional part in the 32-1250 that is only used on the rear caliper?
    Edit: The 32-1250 apparently comes with a spring to hold something on...
    Ben
    Website/Blog
    The standard caliper and XJ front caliper share the same caliper piston diameter and seal, but the outer dust seal is different. The XJ just has a small 'mini-seal' and leaves the outer surface of the piston exposed. The standard has a 'full' dust seal that's held on with a round spring clip...
    The '79-81 Special front uses the same kit as the XJ rear, that may be the kit you have. This kit won't fit the '78 brakes...
