This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
1978 XS1100E K&N Filter
ATK Fork Brace LED Dash lights
Ammeter, Oil Pressure, Oil Temp, and Volt Meters Green Monster Coils SS Brake Lines
I'm pretty sure those Maier ones will fit the bill for you a lot better than the one in the photo, if you could get one of them, that is. That's a factory Yamaha XS1100 fairing (5k7 / 5N5) and the headlight hole is about 8 1/4" diameter to cater for the 8" headlight - not the usual 7 incher.
