so ive found a leak, dont know what it is though...its motor oil i believe, its coming from a 12mm bolt head directly under neath the timing cover on the left side of the bike....
strange oil leak ...
79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
09 YZF-R1 " Toothless"
04 Buell XB12R "Butterfly"
"I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
Wolf
Moto Militia MCTags: None -
Take off your timing cover and see if it's a crank seal leaking.. or that oil galley plug underneath it.. and dripping down off that bolt.Try your hardest to be the kind of person your dog thinks you are.
*Crashed/Totalled, still own -
well, im learning as i go, but you have just stepped outside of my knowledge base...what am i looking for?79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
Moto Militia MCComment
this is where the leak is coming from...my bad the pic is upside down...
Wolf
as tod said, remove the timing cover,
theres a seal that sits in the cases behind
the pick up coils/timing plate, its more likely to be leaking
from that seal than the bolt.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
just did a quick search
heres a link with some pics and seal info.
pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Dont try tightening that bolt hust yet, I thought I just read another fella that tried tightening it and it snapped off... follow up with checking under the side cover for crank seal leak before anything. If the seal leaks it will drain out the bottom of that engine cover right at the bolt you think is leaking.
Idk, maybe your dealing with a different issue... someone will correct me if I'm wrong. Her was the thread...
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
It's very tough sometimes to find out exactly where an oil leak is coming from, not just where it ends up. I've seen oil leaks where you speak of by the valve cover leaking into the middle of the head by spark plug #2, then wind pushing it back through the cooling fins where it drips on cylinder cooling fins. With the motor angled forward, this lets the oil end up dripping from the FRONT of the motor, or down there by that bolt by dripping off the carb boot.
Anyway... from your pic, I can't tell which bolt you are refering to. Is it the galley plug with the white arrow, or one of the other two bolts in red?
IF you go to the effort of replacing the crank seal behind the timing plate, I woudl also replace the o-ring seal of that bolt. Can't hurt anything. And yes, this is one of those places where a torque wrench is your friend. Applying the proper torque will ensure a good seal, and not cause a broken bolt.Life is what happens while your planning everything else!
78 XS750Comment
