strange oil leak ...
  • Filter
  • strange oil leak ...
    so ive found a leak, dont know what it is though...its motor oil i believe, its coming from a 12mm bolt head directly under neath the timing cover on the left side of the bike....
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
  • #2
    Take off your timing cover and see if it's a crank seal leaking.. or that oil galley plug underneath it.. and dripping down off that bolt.
    • #3
      well, im learning as i go, but you have just stepped outside of my knowledge base...what am i looking for?
      Wolf
      Moto Militia MC
      • #4
        this is where the leak is coming from...my bad the pic is upside down...
        Wolf
        Moto Militia MC
        • #5
          as tod said, remove the timing cover,
          theres a seal that sits in the cases behind
          the pick up coils/timing plate, its more likely to be leaking
          from that seal than the bolt.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • #6
            just did a quick search
            heres a link with some pics and seal info.
            http://www.xs11.com/forum/showthread...ght=crank+seal
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • #7
              Dont try tightening that bolt hust yet, I thought I just read another fella that tried tightening it and it snapped off... follow up with checking under the side cover for crank seal leak before anything. If the seal leaks it will drain out the bottom of that engine cover right at the bolt you think is leaking.
              Idk, maybe your dealing with a different issue... someone will correct me if I'm wrong. Her was the thread...
              http://www.xs11.com/forum/showthread.php?t=37286
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              '84 Chevy K-10 "Big Blue"
              • #8
                It's very tough sometimes to find out exactly where an oil leak is coming from, not just where it ends up. I've seen oil leaks where you speak of by the valve cover leaking into the middle of the head by spark plug #2, then wind pushing it back through the cooling fins where it drips on cylinder cooling fins. With the motor angled forward, this lets the oil end up dripping from the FRONT of the motor, or down there by that bolt by dripping off the carb boot.
                Anyway... from your pic, I can't tell which bolt you are refering to. Is it the galley plug with the white arrow, or one of the other two bolts in red?
                • #9
                  IF you go to the effort of replacing the crank seal behind the timing plate, I woudl also replace the o-ring seal of that bolt. Can't hurt anything. And yes, this is one of those places where a torque wrench is your friend. Applying the proper torque will ensure a good seal, and not cause a broken bolt.
