Need to clean?
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Need to clean?
    I just got a set of carbs from Diverray. I was going to soak them tonight but after pulling off the bowls, they look virtually spotless. Should I skip the cleaning or should I dig deeper to look?
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    Hi Nate,
    just bung them on and push the button. You might get away with it, eh?
    • Tat2demon
      • Jun 2012
      • 718
      Started looking a little deeper and figured Id give them a good soak just to be sure. Overall things went very good. But I have a couple questions.
      Two of the idle screws are a little deformed. Anything I should worry about or are these still useable?
      Two of the fuel Ts are a bit rotted and dont fit tight. A problem?
      Last, when I took the diaphragm out of the last carb a small BB fell out with it. I cant see anywhere it could have came from. Ideas?
      Thanks a lot.
      Nate
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
        Yeah, you will need to replace those idle screws. there is also a fix for those T's or there are replacement brass ones available but they are about $20 each.
          They are out of stock.
          YAMAHA CARB TEE FITTING
          You have to repair your tees or find another replacement. Somewhere in this forum is a repair.
            I can't locate the original, but I saved BIKERPHIL's repair that he posted.
            Bikerphil's fuel tee repair
            • TADracer
              • 1417
              • Kenner, Louisiana USA
              [QUOTE=Tat2demon;379814]Last, when I took the diaphragm out of the last carb a small BB fell out with it. I cant see anywhere it could have came from. Ideas?QUOTE]
              The small BB came from the end carbs where the choke (enrichener) shaft goes through the body of the carb. They sit in a hole on top of small springs that act as the detent to hold the choke in the half or full on position. There should be another one and two small springs. Find them!
              Mike Giroir
              79 XS-1100 Special
              • XS11UFO
                • May 2012
                • 74
                • Palatka, Fla.
                Find the springs!
                Take it from someone who knows find the springs. I was well warned but still lost mine - $9 each, crap!
                The ball bearings are findable.
                Scott
                1978 R100S BMW
                  For you poor souls who lose those, I offer replacements (both springs/balls for $5)... send me a PM for details.
                    I hope you didn't soak the carbs in carb cleaner !! If you did NOT pull the seals from the butterfly shaft first, you WILL have to pull them and replace them. That can be a few hours, and fun trying to pull the butterfly screws off. The ends have been peened over so they cannot come loose and end up in the engine.
                    Sent you a PM about the missing part.
                      I have had luck finding things on the garage floor. If it is dark in the garage and the floor is reasonably clean, you can shine a beam of light along the floor. The long shadows can help you find small things.
                        +1 do that all the time! When things are dirty or they fall under things is when it gets real hard!
                        • Tat2demon
                          • Jun 2012
                          • 718
                          Used Pinesol so should be good.
                          I didnt get any other BBs or springs that came out. Guessing they were gunked up too much? Will be careful when I pull parts out of the bucket.
                          Nate
                          K+N Air Filter
                          88 Voyager XII
                          81 XJ650 Maxim
                          • Tat2demon
                            • Jun 2012
                            • 718
                            Are the idle screws something common that I may be able to get here in town or will I need to get them online?
                            Nate
                            K+N Air Filter
                            88 Voyager XII
                            81 XJ650 Maxim
                              Any dealer or shop that deals with motorcycles should be able to get them. Georgefix on ebay is where a lot of people here get their carb parts.
