Hello I just got the ebc ck2230 kit. I am not sure that it is going to work on my bike. I found a few single plates on ebay and they listed all the xs1100s so I got the kit. I also got the gasket YM-309 wich seems to work for all xs1100s too. Can anyone confirm this?
clutch plates for xs1100g 1980
Can't confirm/deny the plate numbers, but I would advise you to leave them on the shelf, put in some Barnett clutch springs with your old discs, and ride it. In all the motors I've had apart, I've only seen one or two clutch friction discs slightly out of spec thickness, and that's being harder on them than the average guy with wheelies and tons and tons of stoplight launches with a 750/850 final drive. Even IF the clutch plates are out of spec, the Barnett springs will fix you up. And don't be fooled into spending a couple bucks less on cheaper springs. I've been through probably a dozen cheaper "Heavy Duty" sets of springs.. changing them 2-3 times a year in some cases.. and have had these Barnetts in there 2 or 3 years. They'll get that clutch to hook back up for you.Try your hardest to be the kind of person your dog thinks you are.
Originally posted by trbig View PostCan't confirm/deny the plate numbers, but I would advise you to leave them on the shelf, put in some Barnett clutch springs with your old discs, and ride it. In all the motors I've had apart, I've only seen one or two clutch friction discs slightly out of spec thickness, and that's being harder on them than the average guy with wheelies and tons and tons of stoplight launches with a 750/850 final drive. Even IF the clutch plates are out of spec, the Barnett springs will fix you up. And don't be fooled into spending a couple bucks less on cheaper springs. I've been through probably a dozen cheaper "Heavy Duty" sets of springs.. changing them 2-3 times a year in some cases.. and have had these Barnetts in there 2 or 3 years. They'll get that clutch to hook back up for you.Last edited by WMarshy; 06-28-2012, 07:32 AM.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
Originally posted by WMarshy View PostSince he already bought them and is going into the clutch 80% of what it take to replace the frictions, I would advise you to just replace them and enjoy another 30 years of good operation... just my 2 cents.
My point is that there's usually nothing wrong with the originals, so why replace what ain't broke? Even new frictions are going to slip with crappy springs. Then, if you ever do need them.. you've got them.Try your hardest to be the kind of person your dog thinks you are.
Originally posted by trbig View PostMy point is that there's usually nothing wrong with the originals, so why replace what ain't broke? Even new frictions are going to slip with crappy springs. Then, if you ever do need them.. you've got them.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
Originally posted by JCHarth View PostThanks I got the springs. I might as well do that too. Can I drive the bike with the clutch sleepery or will it break things even more? So plates, gasket and springs should do the trick. Do I need the spacer plates too?
You should soak the frictions in an oil bath for an hour or so or at a minimum, make sure they are completely soaked (I dont who determined the time frame or if it truly is necessary).Last edited by WMarshy; 06-28-2012, 08:37 AM.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
I saw a video on you tube and it seems like a easy procedure. Almost easier that replacing the clutch lines on my new bike. Do I need to train all the oil before changing the clutch plates or would leaning the bike on the peg do the trick?
You can just lean it n the sidestand.Try your hardest to be the kind of person your dog thinks you are.
Originally posted by JCHarth View PostI saw a video on you tube and it seems like a easy procedure. Almost easier that replacing the clutch lines on my new bike. Do I need to train all the oil before changing the clutch plates or would leaning the bike on the peg do the trick?
http://www.xs11.com/forum/showthread.php?t=9481
If you were doing just the springs you could do it on the side stand as all the oil would go to the low side but since you need to take the basket off to chance the frictions it would be easiest on the center stand...'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
Why? What's the difference?Try your hardest to be the kind of person your dog thinks you are.
I wasn't asking that because I didn't know the answer, I just didn't understand your reasoning is all. When you replace the springs, you're right there at the basket. Only thing left to do is zip off one nut and pull the basket.
The only reason I'd drain the oil is if I dropped a washer in there or something.
Speaking of washers, there's a large one that sits between the basket and the case and there's a similar one that sits down in the bottom of the clutch basket under the plates. Don't confuse the two. One lets oil get to your clutch shaft bearing and one doesn't. I posted a thread on here somewhere about that.
Oops.. here it is.. 2nd page with pics if it doesn't load that way.
http://xs11.com/forum/showthread.php...h+shaft&page=2Try your hardest to be the kind of person your dog thinks you are.
Originally posted by trbig View PostWhy? What's the difference?'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
LOL.. See, I guess it's just a preference thing then. I move the basket around, not the motor, and the back tire on the ground helps with torqueing the clutch basket nut.Try your hardest to be the kind of person your dog thinks you are.
I was able to install the clutch yesterday. The parts on ebay worked. I used both ebc clutch disks and springs. Also made a bobber seat at home depot
http://www.joeharth.com/07012012835.jpg
