Sputter and cough while accel.
    Hard to tell for sure but it looks like the exhaust cam is off 1 tooth. In the first pic there are arrows on the cam bearing caps and there should be a dot on cam that lines up with the arrow. If the dots don't line up then the cam is off.
      Sometimes those dots and arrows don't line up perfectly but they should be very close.
      • kevkat8
        • Sep 2010
        • 37
        • Cranston,RI
        The alignment dots on the cams are at the pointers on the cam bearing caps. Well the intake one is spot on and the exhaust is less then a 1/16" off or less to the mark.
        I don't think it skipped a tooth guys.
          If it is that close then that's not it.
          • kevkat8
            • Sep 2010
            • 37
            • Cranston,RI
            Think I'm going to replace both sets of pick-up coil wires. I fixed one last year but should have done them all. I still have that feeling that this is the problem. Any other ideas b4 I do this?
            • James England
              • 3039
              • North of England
              Looking at photo 2, both cams appear to be wrong. Dot on left camshaft is at 1 o'clock and the dot on right camshaft is at 11 o'clock. Or is it just some flash?
                It's reflection James. He already checked the timing marks.
                • James England
                  • 3039
                  • North of England
                  I've put pointers on to where it looks like the dots are. Is this flash?
                  • kevkat8
                    • Sep 2010
                    • 37
                    • Cranston,RI
                    Thanks James but it is the flash. The marks do line up VERY CLOSE if not right on.
                    • James England
                      • 3039
                      • North of England
                      That's OK then! Just double-checking. No disrespect to you but sometimes people say, for example "Yes, I've got the oil level right" and then, when you see some pix, you find they thought it was 'right' when the sight window was completely full! Or "yes, the marks line up" but then you find that their idea of lining up isn't correct. Hence me double-checking.
                      Right, so the dots do line up, so we can rule that out. Re the pickup wires.... mine did the 'hourglass' thing but I'd never had any problem with the bike. I checked them after joining the forum and, lo and behold, found they did have breaks that just hadn't caused a problem yet. I replaced the wires to just bafore the rubber seal in the engine casing. I didn't strip them right back through the wiring harness under the engine (where they are spliced in originally). I figured that the only moving bit is in the ignition casing, so I renewed both wires using multimeter probe cables. I soldered the joins wherethe wire enters the casing and used insulating tape round them. I never had any problems with them.
                      • kevkat8
                        • Sep 2010
                        • 37
                        • Cranston,RI
                        Thats what I will do. Thanks for the information. I have some extra multi meter test leads so I'll use those. I'll let you know how this makes out. Might take me a day or two to finish it up and put everything back together.
                        • kevkat8
                          • Sep 2010
                          • 37
                          • Cranston,RI
                          Here are some better photos of the can chain alinement marks.
                          A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                          Should have taken better pics the first time.
                          • James England
                            • 3039
                            • North of England
                            Oh yes, they're definitely OK. Better to be sure though...
                            • kevkat8
                              • Sep 2010
                              • 37
                              • Cranston,RI
                              Well I got the valve/cam cover on tightened up. I just checked the resistance for the pick-up coils at the TCI four connector.
                              Wht/red to wht/green: 755 ohms
                              yell/green to yell/red: 768 ohms
                              Do I have a problem. I thought it should be somewere around 720 ohms?
                                No those are fine, as long as you pulled and tugged and moved the wires around to check for breaks inside the insulation as you checked the ohms.
