How to remove these covers?
    • 9981
    The only purpose a gasket would serve is possibly to keep some dust out but it really wouldn't make much difference because there is nothing sealing in between it and the lip on the starter end cap.
      Now that's weird, because I've found a thin paper gasket on every one I've pulled.
      But the parts fiche also doesn't show a gasket, so WTF...
      LOL.. I had no clue what you were talking about. I've been into a quite a few of these motors and have never seen any sort of gasket there.. or even anything like stuck gasket material. I know for a fact that at least two of them (The motors) had never been touched mechanically.
      I started thinking about if it was something they'd maybe done to earlier motors, but my first motor was from a '78, and there wasn't anything there on that one either?
        • 9981
        Originally posted by BA80
        OK boys. Some pics.
        The bearing cover/retainer for the starter clutch idler gear.
        I was mistaken about that. That is actually the bearing for the main shaft. Sorry
        • KA1J
          • 664
          • Groton, CT
          Update...
          I've finished polishing all the bare aluminum engine parts except the left & right engine covers. I've polished the round flat clutch cover & will polish the clutch case when it's off when I replace the friction pads this summer. What I want to do next is polish the left side case cover, the one the shifter runs through.
          Other than draining the oil first, Is there anything I should be aware of before removing this left side case cover or putting it back on? Any good things to know first? I'll be using anaerobic sealant instead of a solid gasket.
          Thanks
