1st gear clunk
  • Guest
    1st gear clunk
    When ever I start the bike up in neutral and let it idle and then try to put it in first gear I get a big clunk. Sounds like the trans will come out the bottom. Is this normal or is there a better trick when going from neutral to first. If I shut the bike off and put it in gear, that works.
  • James England
    • 3039
    • North of England
    It's normal. You'll find the clunk is louder when the oil is cold. I usually let mine run for a minute or two to warm up the oil and then engage 1st gear. In cold weather mine put out a huge clunk and tried to move....the cold oil was making the clutch drag...mind you it was minus 10 at the time.
    You may find that sometimes there's hardly any clunk at all. Other times there is. I could never figure out why. All 4 of my XS1100's have done it.
      If your idle speed is higher than 1100 RPM, the clunk will be greater, try a slightly lower idle speed. Also, hold the clutch in for about 5 sec. before shifting into first.
      • mjpxs11sh
        • Jan 2011
        • 299
        • N/E, Illinois
        the XS def has a noisy 1st gear clunk, esp with the choke on and 1500-2000 rpms. like James said, sometimes its fine. its been buggin me forever cause i dont get it. if u take off quickly after first start and warm it up while riding like i do in the riding season, just start it up in gear with the clutch disengaged, take off and let the oil warm up. when i get it on the street after take off and theres no stop signs, i push the choke detent in to 1/2 cause mine doesnt want to stop with clutch engaged and a full choke. mine seems to shift smoother after i put Mobil 1 Air Cooled Engine 20W50 in it this year. just my exp. i dont want to start the oil debate, but it works for
        me
        Max
        81 XS1100SH Black Beast Mutt
        Kerker 4/1
        stock carbs and air box.
        78 headlite, handle bars,
        1 set of ea-160/85mph guages,
        crash bars, cruise control
        Other 2 Wheelers
        78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
        94 CBR1000F jet kit,Two Bros pipe, K&N Filter
        • WSL91
          • Feb 2012
          • 427
          • Quad Cities, IL
          both my XS and XJ do it warm or cold. Both bikes are a bit noisey going from 3rd to 4th as well. Kinda fells like you are shifting your foot through a box of wrenches. I always chuckle cause I know where I am.
          1970? Honda Z50... gone
          1974? Yamaha 100 Enduro... gone
          1974 Honda CB200... gone
          1981 Yamaha Virago 750... gone
          1993 Honda Shadow 1100... gone
          2008 Honda VTX 1800F
          1982 Yamaha XJ1100J w/850 final, Raptor ACCT
          1979 Yamaha XS1100SF "Chewey" Raptor ACCT
          http://www.johnsoldiron.com
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            It's where the term "shifting like a Russian tractor" comes from, that being what these bikes are characterized as shifting like. That said, other than the 1st gear clunk, once you get good at engine speed matching, you can get to where all the other shifts are pretty smooth and noiseless.
              same here, 1-3 and 3-4 are noisy but 2-3 and 4-5 are always smooth.
                If your bike sat for a long time, the clutch plates may be unsaturated with oil. If this is the case, things will get a little better with riding the bike, especially if you leave it in 1st gear at red lights with the clutch pulled.
                • James England
                  • 3039
                  • North of England
                  Pull the clutch lever in and tie it open with a cable tie or bit of string. Spin the engine and leave it for a few hours. Oil will get bewteen the plates and soak in a bit
