yet another carb question
  • Shockman54
    • Feb 2012
    • 145
    • Minneapolis, MINN.
    ok, so i have gotten my carbs to the point were i can ride the bike whenever, but there is still too much hesitation in the low rpms. i tried adjusting the idle mixture screws, but if i go any lower than 3 1/2 turns from seated, the bike won't start or run. now it has a nice idle, but won't rev up easily until it hits about 4k rpms. if i put the choke on, the bike dies (i assume from too much gas) under load the problem is a bit worse, but not so bad that i can't ride. (also, under load at about 7-8k rpms, it slows a bit too) btw, i have mikes xs oval pod filters (oiled) and harley sportster muffs on stock headers (no cat converters) so my question is, what do you think the problem is? wrong float height? pilot jets? main jets? just need to be tuned with a gauge? all electrical and mechanical is good too...
    1979 xs special, just finished the top end rebuild and then i still have lots of work.
    progress thus far...
    http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
    "If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -Incubus
    With the PODs and the exhaust you have, typically stock jetting will work.
    HERE is a link to carb tuning process. It may help you out.
      • 1591
      now it has a nice idle, but won't rev up easily until it hits about 4k rpms. under load the problem is a bit worse, but not so bad that i can't ride. (also, under load at about 7-8k rpms, it slows a bit too) btw,...
      Just a thought ...... What size Pilot Jet are you using?? Are you sure the Pilot Jet is not clogged?? Diagnosis that: Idles ok but does not Rev to 4K very well might indicate clogged pilot jet or circuit. Also, did you do bench sync the carbs?
      If you are 100% sure the pilot jets / circuit are clean & clear then the tuning guide DGXSER provided should either fix the problem or eliminate pilot circuit as the issue.
      • Shockman54
        • Feb 2012
        • 145
        DGXSER, thats a great guide, definitely going to use that site. has anyone used their products before? if so, what jets are the ones we use? i'm not seeing exactly which kind to order (i can figure out the sizing, just not which actual parts to get)
        • mjpxs11sh
          • Jan 2011
          • 299
          • N/E, Illinois
          _
          id go thru the carbs and keep the stock parts fist and get it running right b4 making any changes. anyway, thats where i started otherwise u may be chasing gremlins in a vicious circle. if u want to change jets for whatever reason, stay with mikuni oem.
          Max
          81 XS1100SH Black Beast Mutt
          Kerker 4/1
          stock carbs and air box.
          78 headlite, handle bars,
          1 set of ea-160/85mph guages,
          crash bars, cruise control
          Other 2 Wheelers
          78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
          94 CBR1000F jet kit,Two Bros pipe, K&N Filter
