Diagnosing a weird issue
  • jimbyjimb
    • Feb 2010
    • 263
    • Seattle
    Originally posted by GLoweVA
    It's amazing how much power these old bikes have when they're running on all 4!
    I've seen that the 78-79's are a bit more powerful than the 80-81's.
    Kinda of wish I had done some research into that before I picked up my SG project.
    However, it has been nice to have a readily available parts bike sitting right next to me when ever I needed a part, it's right there!
    I would LOVE a 78. I have never even seen a 78 for sale here. I think people tend to like that year a bit, plus 1980 is a super common year.
    1990 Ninja ZX-10. It's the Silver Surfer. HI-YA!!
    2006 Yamaha XT-225. Yep, I take it on the interstate. It's Blue Butt.
    1982 Toyota 4x4. 22R Cammed, 38/38, 2" pipe, 20R head with OS valves, performance grind and other fun stuff. It's Blue RASPberry.
    1969 Ford F-250 Camper Special resto project. 390 RV cam, Demon carb, Sanderson headers, 2 and a quarter pipes with Magnaflow mufflers. It's Blue Jay.
    • Fix
      • May 2009
      • 384
      • Lake Orion, MI
      Sure as ****, the throttle cable snapped in the throttle housing and got caught. Looks like I'm ordering a new cable. Might as well do the clutch while I'm at it. Not sure how old that one is.
      Mike C
      Lake Orion, Michigan
      '78 XS1100E
      Here I am! Where are you?
      • Fix
        • May 2009
        • 384
        • Lake Orion, MI
        http://www.motorcycle-superstore.com...100-Parts.aspx
        Will that work on a 1978?
        Mike C
        '78 XS1100E
          All the XS11's, all years, use the same replacement throttle cable. The cable will fit both Standards and Specials. The one in the above link should be fine.
          Edit: Here is another source for the cable, also shows that it fits all XS11 models...
          https://www.denniskirk.com/parts-unl....prd/C4530.sku
          • Fix
            • May 2009
            • 384
            • Lake Orion, MI
            Thanks Phil!
            Mike C
            '78 XS1100E
            • Shacknasty
              • Feb 2011
              • 379
              • SFV-SoCal
              Short-shifting and running at low rpms should be avoided. Let yer motor sing!
              • Fix
                • May 2009
                • 384
                • Lake Orion, MI
                Hmm, seems the issue's back. I can't find any wires broken, but it's cutting out randomly. The way to recover is to pull in the clutch, let the revs drop, and then let out the clutch. Kind of a 70mph push start almost.
                It seems like it's gotta be the same issue, the loss of power feels exactly the same.
                One thing I've noticed, with the timing cover off and the bike running, should I see the advance moving at all? It's not moving, at least that I can see.
                Mike C
                '78 XS1100E
                  Remove the vacuum advance can and make sure the advance assembly is floopy loose rotating it. It rotates on ball bearings similar set-up as a lazy susan.
                  • Fix
                    • May 2009
                    • 384
                    • Lake Orion, MI
                    Ok, I'm kind of slow. What part is the vacuum advance can? The plastic part that the wires attach to will move if I move it with my fingers. It feels spring loaded and pops back to position.
                    Mike C
                    '78 XS1100E
                      Remove the left side timing cover(one that says YAMAHA on it), push the vacuum hose off the connection, remove the retainer clip that holds the vacuum can shaft in place, remove the phillips screw that holds vacuum can in place, lift it up and at same time rotate it a bit so the vacuum hook-up tube clears the case. Now with your hand rotate the advance assembly on the side of motor. It Should be 'floppy' loose rotating back and forth. Doing that you can also see the movement and abuse the wires take over the years. Those are the ones you see talked about on here that will break internally. Also, make sure that vacuum hose is plugged on the nipple on the SECOND carb, not the carb boot itself. The nipple it plugs onto is up close to carb body itself. Report back your findings......
                        • 3372
                        YES, what Motoman says is on the right path. Take off the pulsar cover/timing cover/whatever you want to call it cover, and lubricate the base plate or whatever it is that the timing unit rotates on. Mine did the same thing, the engine would just bog flat, would not pull out of the rpm it was at, unless I'd pull the clutch in, downshift it then go back up to the gear I had just been in.
                        When I had it apart, it was SO nice and clean in there, and it sure seemed like it was rotating easily. UNTIL I LUBED THE BASE PLATE, and then it did rotate ever so slightly easier to my hand. As well, you should be able to easily suck on the vacuum line and watch the thing rotate as well.
                        So, don't jack with the pick up wires until you use some silicon spray on that base plate and work it around a bit by hand. If it doesn't come around, then go check the pick up wires.
                        I promise this will help.
                        2001 ZRX 1200
                        1982 Seca 750
                        1983 Nighthawk 550
                        • Fix
                          • May 2009
                          • 384
                          • Lake Orion, MI
                          The vacuum hose was fine and correct. Removed the can as instructed. The advance assembly feels almost chunky. It is anything but floppy.
                          Mike C
                          '78 XS1100E
                            • 3372
                            Floppy may be a bit overstated, but chunky it should not be!
                            If it feels chunky when you rotate it by hand, do what I shared above and lube it with some silicon spray while rotating it back and forth. That will loosen it up, then you can check one more thing off the list of what you have done, if it somehow still isn't working right. What do you have to lose?
                            I really feel that is where the answer lies.
                            2001 ZRX 1200
                            1982 Seca 750
                            1983 Nighthawk 550
                            • Fix
                              • May 2009
                              • 384
                              • Lake Orion, MI
                              Howard,
                              When you say to hit it with silicon, I assume you're talking about taking it off and hitting the inside where it's actually contacting?
                              Mike C
                              '78 XS1100E
                                • 3372
                                I did it a couple years ago so my terminology might not be spot-on. However I simply put a shot(s) of silicon spray on the mechanism where it rotated. The timing mechanism rotates with the vacuum, and it was at the base of where the mechanism rotates that I sprayed the lube.
                                I looked at it and said "Hmmm... nice and shiny in here under the timing cover, but any lubrication this initially had from the factory probably isn't working any longer"... Then I said "if something is a bit sticky, what looks like a good spot for a shot of lube based on how this thing functions?"
                                Then put the lube there, and it loosened up a little bit (it was pretty free moving already, so I was also thinking it didn't need any lube based on my initial gut reaction), and the problem has not returned. What I thought was good and loose, was not good and loose apparently.
                                Don't go crazy with the silicon in there, as it doesn't need to get all over everything, but put a judicious squirt where it looks like it could use some lube based on how it rotates, and that is what I did.
                                2001 ZRX 1200
                                1982 Seca 750
                                1983 Nighthawk 550
