battery cables
  • kevxs
    • Apr 2009
    • 353
    • toronto
    battery cables
    hi guys, kinda dumb question but here goes. i cant find one of my battery cables. i can see the short one that goes from the battery to the solenoid which i assume is the positive cable (please confirm) but i can find the negative cable, i didn't remove it so i just need some help tracing it from where it goes. any help is appreciated, i'd like to finally ride today. thanks
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
  • petejw
    • 2269
    • sydney australia
    hey kev, the pos lead does go to the solenoid,
    the negative lead from memory is on the left side
    of the frame near the side cover lock, then another
    lead goes from there usually to the mid drive.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • kevxs
      • Apr 2009
      • 353
      • toronto
      thanks pete, what you say makes perfect sense but i still dont see the negative lead. here is a pic
      should i just buy a new lead and hook it to that screw with the other lead right under the tool compartment? thats what it looks like in the manual
      i dont know what happened to my negative lead! i guess it walked off during the winter
      Green Dyna Coils
      1973 CB100
      kevXS
      • petejw
        • 2269
        • sydney australia
        Im on my fone atm bit hard to see,
        but u can get urself another lead and attach it
        to that screw,
        i also used to run another lead from the neg batt
        to the regulator for extra insurance.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
          • 5061
          Just going from memory, but I do not remember another cable terminating at the same location as the negetive cable. What does the end of that existing cable go to anyways? (Maybe that is it?)
            Originally posted by kevxs
            ...but i still dont see the negative lead. here is a pic
            Your negative lead is there, but appears to be hooked to something else??!! The big wire connected to the frame right below the toolbox should go to the battery....
              It looks like the neg lead is shoved into the crank case vent tube.
              • jwhughes3
                • 2798
                • Home of the Alamo
                good eye nate
                Youthful eyes are sharp!
                John
                '81 XS1100H - "Enterprise"
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  Now you opened up a can of worms, Nate. Now you're gonna have to figure out where the breather tube goes. CZ
                  • kevxs
                    • Apr 2009
                    • 353
                    • toronto
                    thanks guys, got it figured out, put everything back together and she's runnin like a dream!
                    Green Dyna Coils
                    1973 CB100
                    kevXS
                      • 5061
                      WHAT? You mean you aren't going to tell us what the issue turned out to be after all?
                      • kevxs
                        • Apr 2009
                        • 353
                        • toronto
                        the cable was shoved into the crankcase breather, i got pokin around and out it came. haha i knew it was something stupid like that.
                        Green Dyna Coils
                        1973 CB100
                        kevXS
