Shocks
  • mack
    • 2411
    • Ontario, Canada
    Shocks
    Would it be a safe assumption that the fluid in the shocks is the same as fork oil? Pulled my leaky shock off the LH today and found that the o ring on the respirator shaft was the culprit. I can replace that o ring easy enoug, but I'm not sure what oil to use to replace the old stuff and how much to put in before replacing the shaft.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    It probably uses 5W suspension/fork fluid. How much to use is anybody's guess,
