So in the post below it says "start jet"... So where is this start jet located?
Carb start jet location?
USMC 2005 - Present
79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
78 XS1100E - Rebuilt And SoldI SHOULD OF KEPT IT!!!
Tags: None -
The starter jet is pressed into the aibox side of the venturi and is non servicable. I don't know why they list it other than just to show the differences year to year.Greg
The list changes. -
Alright so the difference between the 78 and 79 carbs shouldn't be a problem then right? So I can take my carbs off a 79 and put them on a 78 and it should run fine even with the different pilot and start jets right?USMC 2005 - Present
I run 79 carbs on my 80. Well I did on the 80 engine and it ran great. I still have the 79 carbs but I now have a 79 engine in my SG also.
You'll be fine. If you'll notice the 78 is the only year they had that particular starter jet and pilot jet. 79 they went to smaller on both. No doubt an engineering correction.
80-82 was a different design carb.Greg
The list changes.Comment
Thanks. Well if anyone has 1pilot air jet that is a 180 I would love to buy it from you. All I am missing is 1 to have a complete set of carbs. I don't want to get a whole rebuild kit just to use 1 pilot air jet.USMC 2005 - Present
Well actually I just found 1 in the parts box that came with my 79. Thanks again for the infoUSMC 2005 - Present
