79 carbs
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    79 carbs
    I took my first set of 79s apart to clean and unlike my 80/81s, I don't see a washer/o-ring for the air needle. Should they have been there?
    1980 LG
    1981 LH
    Nope, the early carbs only have the needle and spring....
      • 3193
      Nope. The early carbs do not have them. Different shape to the screws too.
        Nope, much simpler and way more adjustable.
        • dpotter58
          • Aug 2004
          • 1866
          • Southern Maryland
          I was hopeing that was the answer.
          thanks
          1980 LG
          1981 LH
          • dpotter58
            • Aug 2004
            • 1866
            • Southern Maryland
            Different set of 79 carbs, The small screws and washers that cover the pilot jet are missing. Can I just get some from the local hardware store or are they something special?
            1980 LG
            1981 LH
              You mean the plug screws?
              • dpotter58
                • Aug 2004
                • 1866
                • Southern Maryland
                I'm talking about the screws that are beside the main jet.
                1980 LG
                1981 LH
                  Here you go....
                  http://www.powersportsplus.com/parts...TOR/parts.html
                  Looks like they have 'em #21 and #55.
                  • dpotter58
                    • Aug 2004
                    • 1866
                    • Southern Maryland
                    Originally posted by BA80
                    Here you go....
                    Right. but, are they special or just brass screws that I can pick up at the hardware store? 30 bucks for the 4 each is kind of steep
                    1980 LG
                    1981 LH
                      I dunno. Let me know how that turns out for you.
                      Looks more like about $32 for all to me. Still high but WTF.
                        I don't think they're 'special', but length may be an issue. The OEM ones are pretty short (about 3/16"), as long as you match that I'd go for it....
                        • mack
                          • 2411
                          • Ontario, Canada
                          Plugs
                          How many do you need, I probably have few spares. If I remember right there is washer required as well.
                          mack
                          79 XS 1100 SF Special
                          HERMES
                          original owner
                          81 XS 1100 LH MNS
                          SPICA
                          78 XS 11E
                          IOTA
                          https://youtu.be/wB5Jfbp6SUc
                          https://youtu.be/RaI3WYHSuWA
                          Frankford, Ont, Canada
                          613-398-6186
                          • dpotter58
                            • Aug 2004
                            • 1866
                            • Southern Maryland
                            all 4 are missing
                            1980 LG
                            1981 LH
                            • mack
                              • 2411
                              • Ontario, Canada
                              Plugs
                              Yes I just checked and I do have four you can have. Do you need them right away or shall I just bring them up to Haliburton for you?
                              mack
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              613-398-6186
